Suspension lug bolts
Old Oct 26, 2012 | 11:31 AM
Roly727's Avatar
Roly727
lug bolts
What length lug bolt would i need to get in order to mount a 15x8 et0 rim on a non s stock suspension?
Old Oct 26, 2012 | 03:31 PM
ALTAPerformance's Avatar
ALTAPerformance
stock bolts unless you are using spacers.
Old Oct 26, 2012 | 04:08 PM
Roly727's Avatar
Roly727
for some reason they dont fit
Old Oct 26, 2012 | 04:52 PM
kcle730's Avatar
kcle730
You need aftermarket bolts which has a smaller diameter bolt head which wud fit.
Old Oct 26, 2012 | 05:00 PM
Roly727's Avatar
Roly727
is there anyway you can give me a link or can i get them locally ? i know the r56 are 14 not 12 but if you can show me which ones exactly ill appreciate it tremendously
Old Oct 26, 2012 | 05:18 PM
Creeve's Avatar
Creeve
You can't get them locally. You will have to order them, to my knowledge the only place that sells a 14 -> 12 conversion is Way Motor Works in Georgia.
As a side note 15x8 et0 is going to stick pretty far out of the fender on a Mini. Around 30-35mm beyond the fender and about 60mm more then stock.
Old Oct 26, 2012 | 08:06 PM
Roly727's Avatar
Roly727
these? http://www.waymotorworks.com/14mm-lug-bolts.html ? and yea its a lot of poke temporary while i get the money for new tires
Old Oct 27, 2012 | 05:21 AM
Creeve's Avatar
Creeve
http://www.waymotorworks.com/m14-to-...rsion-kit.html
Old Oct 27, 2012 | 10:22 AM
Roly727's Avatar
Roly727
i have to get the conversion kit or can i just get bolts
Old Oct 27, 2012 | 11:06 AM
Creeve's Avatar
Creeve
You have to get a conversion to use 12mm hardware. Can't put a 12mm bolt in a 14mm hole. To be honest based on the information (or lack of) supplied thus far I'm not 100% convinced you need a conversion.
Old Oct 27, 2012 | 11:48 AM
kcle730's Avatar
kcle730
Here you go man, this is how they look like, as u can see, they have a smaller diameter head, which would fit thru the wheel holes.
hope this helps!
Amazon Amazon
Old Oct 27, 2012 | 11:50 AM
kcle730's Avatar
kcle730
BTW! make sure the thread/pitch is right! i havent bought a set for an R56 yet so im not sure
Creeve's Avatar
Creeve
hope this helps! http://www.amazon.com/Gorilla-Automo...s=Lug+Bolts+14
Those are 14x1.5mm our lugs are 14x1.25mm just to be clear.
Old Oct 27, 2012 | 12:38 PM
kcle730's Avatar
kcle730
Thank you sir! here's another link =]
Amazon Amazon
these are just example of how/what to look for! make sure u find the right seating for ur wheels too! lmk if u have any questions and i'll try to answer them.
Old Oct 27, 2012 | 01:15 PM
Creeve's Avatar
Creeve
This may or may not be the solution BTW. It may be the case that the diameter of the through hole is smaller then 14mm in which case you would need the stud conversion. For all I know the wheels are the wrong bolt pattern. I have still not heard enough information to give any sort of definitive answer.
Old Oct 27, 2012 | 01:36 PM
kcle730's Avatar
kcle730
yea i know, but i Guess we'll find out when Roly replies back ;]
Roly: one way to find out if u need a conversion is turn the wheel around and poke the hole through the back with ur OEM Lugbolt and see if it goes thru, if it does, then itz the diameter of the head =]
freckles81
Jan 15, 2017 06:33 AM
NYMADMINI
Dec 14, 2016 02:33 PM
buggyeye401
Oct 1, 2015 01:22 PM
buggyeye401
Sep 28, 2015 04:09 PM
EVMini
Sep 28, 2015 10:20 AM
