16" or 17" wheels for Mini Coupe S?
Old Oct 24, 2012 | 08:37 PM
-Fen-'s Avatar
-Fen-
I'm ripping my hair out trying to find something that looks cool with the Coupe's goofy shape around the back end. I've considered these two for each size...
16" : Kosei K4R
17" : Sparco Asseto Gara
What are the benefits of having a 16" wheel over a 17"?
What I'm looking for is something that has a wider offset than stock, is more comfortable and better performing than runflats, and fills the empty void of the tire well.
I'm also wanting to get some Vmaxx coilovers to lower the car a bit. Anyone have any advice? D:
Old Oct 24, 2012 | 09:30 PM
Jim Michaels's Avatar
Jim Michaels
In the case of those two wheels, the 16" wheels are 5.5# lighter each than the 17" wheels. But the 16" wheels also cost more.
Assuming that you maintain OE tire diameter, neither wheel would help fill in the tire well. Lowering with coil-overs should help fill the gap.
Instead of changing wheel offset (which I'd actually prefer), you could move the wheels out some with spacers.
Old Oct 24, 2012 | 09:46 PM
-Fen-'s Avatar
-Fen-
What would you change the wheel offset to?
Old Oct 25, 2012 | 08:53 AM
Jim Michaels
Actually, I wouldn't change the offset to more than 5 mm from stock (48 mm), but that's because I'd want to autocross in SCCA stock classes, which limit offset change from stock to 5 mm. In that case, I'd get the Kosei K4R wheels because they would be legal for SCCA stock classes (and also light weight), with an offset of only 3 mm less than stock.
For someone wanting to move the wheels out (instead of reducing unsprung weight or being stock legal), the Sparcos you mentioned move the wheels out 9 mm more than stock (offset of 37 rather than 48). Some here move the wheels out even farther (with offsets or spacers), increasing negative camber to the point where the outside tops of the tires are about flush with the fender lip, while the outside bottoms of the tires lie outside the vertical plane of the fender opening. I've seen offsets posted here of less than 30 mm.
It might be better to do your lowering with the coil-overs before selecting new wheels in order to see exactly how much room you have left to work with to get the exact look you want.
Old Oct 25, 2012 | 09:06 AM
MarinePMI's Avatar
MarinePMI
That's easy, it's called a JCW fixed spoiler.
Old Oct 25, 2012 | 09:08 AM
-Fen-'s Avatar
-Fen-
I think I'm going to go ahead and do that. That seems like a safe bet. Thanks for the help. Also, does less offset mean the wheels sit out further or more inside?
Old Oct 25, 2012 | 09:23 AM
-Fen-'s Avatar
-Fen-
Hehe I totally agree. However, with my last experience with having the chrome trim being blacked out I think I'll pass on anything related to body work for a while. Car was in the shop close to a month and these guys messed up so much **** on my car.. and they were supposed to be the best custom car shop in the area.
Old Oct 25, 2012 | 09:25 AM
Jim Michaels
The lower the (positive) offset, the more the wheel moves outward.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Oct 25, 2012 | 10:30 AM
-Fen-'s Avatar
-Fen-
It's all starting to make sense now! @ a @
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Terry J
Aug 11, 2015 09:39 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
