Navigation & Audio USB Flash Drive Problems
Old Oct 24, 2012 | 05:55 PM
Mini-LSE's Avatar
Mini-LSE
I have a 16 gig flash drive that is hooked into the stereo. Once I connect the drive the stereo recognizes everything fine. The directories are there and music plays. Once the car is turned off and back on again the USB drive is not recognized. The only way to get it to work is to pull it out and plug it back in. Are there others having this problem. Is it the drive or the Stereo?
Old Oct 24, 2012 | 06:06 PM
Mini-LSE's Avatar
Mini-LSE
I have done some more searching and am thinking the drive is too large?
Old Oct 24, 2012 | 07:13 PM
jacquesew's Avatar
jacquesew
Oh geez....I just ordered a 32G so I could put all my music on it and not have to use my phone. I hope it works.....
Old Oct 24, 2012 | 07:17 PM
chrunck's Avatar
chrunck
I use a 16GB drive in my MINI everyday, so it's definitely not too big.
What year is your car? My wife's 2010 usually takes a few minutes to load, but my 2012 is generally immediately ready.
Old Oct 25, 2012 | 04:44 AM
mattkosem's Avatar
mattkosem
I use a 32GB in my MCS daily. It usually starts playing within 5-10 seconds of starting the car, unless I'm screwing around for a bit before starting (in which case it plays immediately upon startup). It starts reading from the stick once a door is opened as far as I can tell.
--Matt
Old Oct 25, 2012 | 05:31 AM
MarinePMI's Avatar
MarinePMI
I've had this happen occasionally (usually on really long road trips). SA thinks its either heat affecting the drive, or it just rattles loose enough that the connection is intermittent enough to error reading/building the TOC into memory or limit access during play.
Old Oct 25, 2012 | 05:47 AM
Mini-LSE's Avatar
Mini-LSE
My car is a 2010 R57. The strange thing that happens is when you turn the car off then back on again, it looks as if it trying to load but then changes to tuner (radio) ? I am going to try another brand and reformat.
Old Oct 25, 2012 | 06:53 AM
chrunck's Avatar
chrunck
Sounds like business as usual based on our 2010 R55. Sometimes when we start it, it will switch to the radio and after 4-5 minutes USB can be selected again. I keep hoping the dealer will flash updated stereo software at one of the services, but I doubt they ever will unless it stops working altogether.
Old Oct 26, 2012 | 09:24 AM
absoluteczech's Avatar
absoluteczech
my 16gb sandisk works fine. btw if anyone is interested its an awesome little flash drive, because its so small you cant even see its plugged in!
SanDisk Cruzer Fit 16 GB USB Flash Drive
Amazon Amazon
Old Oct 29, 2012 | 10:03 PM
henrytiel's Avatar
henrytiel
I have been using a Verbatum 8gb flash drive for three months in my 2011 Mini S to listen to music, without any problems. Two days ago it stopped working....seems like it doesnt recognize it anymore. I loaded the music on a different/new zip drive and got the same result? any advise?
Old Nov 6, 2012 | 06:57 PM
jacquesew's Avatar
jacquesew
Video Link: http://www.amazon.com/gp/product/B005FYNSZA/ref=oh_details_o04_s00_i00
I got the 32GB of this teensy USB drive. It's the same size as my thumbnail. I loaded it up and it works great. It did fade in and out at first and I thought it wasn't going to work but, once music loaded into the system, it worked well and I can use all the menu features.
Old Nov 7, 2012 | 04:16 AM
mattkosem's Avatar
mattkosem
That's the same one I have, and it works great as well.
--Matt
Old Nov 7, 2012 | 06:52 AM
Day177017's Avatar
Day177017
I don't think it's the flash drive. I have my ipod connected with the Y-adapter and it happens to me too: Where the radio won't recognize it, but after a few minutes it's back on.
Bennyboy
Aug 18, 2015 07:28 AM
M7Speed
Aug 14, 2015 01:50 PM
ludedude
Aug 10, 2015 07:16 PM
