coolant leak MCS 2007
Old Oct 23, 2012 | 01:06 PM
mick.driver's Avatar
mick.driver
First is Mini collant really blue, have few spots and thought it was the windsheild washer liquid. Dealer indicated coolant , and the top suspect is the thermostat as they indicated these are a problem on 1st gen R52 mini's. My MCS is a 2007 convertible which was first gen. Dealship is $500, do they have to take the Turbo off or something?
Also, anyone seen a Factory Service Manual for a R52?
Old Oct 23, 2012 | 01:44 PM
quikmni's Avatar
quikmni
Coolant spots are blue. Thermostat housing/gasket would be highly suspect. $500 is high. If out of warranty, take the car to a local shop that works on Minis. Look around the thermostat housing for pooled liquid or dried white residue from the coolant evaporating to detemine if housing gasket is actually leaking. Could be the plastic coolant tank leaking at the seam. Make sure to keep coolant level topped off until leak is fixed.
Old Oct 23, 2012 | 01:57 PM
mick.driver
Will take a look ..... unfortunately we do not seem to have any local shops that work on Minis .... have to use the Birmingham, AL or Nashville, TN dealerships.
Old Oct 28, 2012 | 07:33 AM
legomini's Avatar
legomini
Not sure where you live, but if the Birmingham or Nashville shops are your dealership options, it may be worth your while to come over to Atlanta and see Way at Way Motor Works. A bit longer of a drive, but no one knows more about these cars.
Old Oct 29, 2012 | 06:20 AM
mick.driver
Dealerships
Thanks ...... i may give them a try, had aa couple of interesting comments about both B'ham and Nashville
Old Oct 29, 2012 | 07:03 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
If you, or you and a friend have any mechanical ability and a few basic metric tools, you can do the job in a few hours. If you'll do a search on "replace thermostat" in the "How To" section, it's spelled out step-by-step. Suggest you replace both the stat and the housing while in there. Order the parts on-line from Way and do it...You'll save $$$ and bond more with your MINI!
Old Oct 29, 2012 | 07:06 AM
submitaweasel's Avatar
submitaweasel
R52's are surpercharged.... -_-
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
Khai
Feb 6, 2017 09:24 AM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
