R56 08' R56 n12 code 287d
Old Oct 19, 2012 | 08:54 AM
polarstar's Avatar
polarstar
Hi, I have a 2007 47000 miles mini cooper with check engine light on, my DIS scan tool has a code 287D inlet vanos actuator, I have swapped vanos valves also changed the oil and still have the code 287d, chain rail guide look fine. Any deal what could be?
Thank You
Old Oct 19, 2012 | 02:43 PM
bluefox280's Avatar
bluefox280
* MINI DTC P0012 (0x287D) - 'A' Camshaft Position Timing Over-Retarded (Bank 1)
The ECU is seeing a mechanical mis-position on the intake camshaft.
That's either because of physical mistiming of the engine, or the timing chain has too much slack in it.
Have that checked IMMEDIATELY!
- Erik
Cereall
Sep 5, 2019 06:05 PM
AdrenaliNate
Nov 4, 2015 07:26 PM
Zettinger
Aug 25, 2015 04:04 PM
patrioticmini
Aug 20, 2015 10:54 AM
