R50/53 Headlight Add-A-Circuit and Tach Screw Sizes
Old Oct 18, 2012 | 12:09 PM
Claurence42's Avatar
Claurence42
Hey Guys,
So I just got done installing a Prosport Boost Gauge and it works perfectly except for that it flickers between amber and white when you turn the headlights on. Many people have had this problem and its due to the wire being to small to power it. I can not find any fuses that are off when the headlights are, and pushing 12v when they are. Has anybody found a fuse like this, I hate electrical wiring.....
Also I somehow lost the two screws that hold the tachometer to the column does anybody know the size of the torx bolt with washer in this diagram #4 http://www.realoem.com/bmw/showparts...62&fg=05&hl=27
Thanks and Happy Motoring!!
Old Oct 18, 2012 | 12:36 PM
Claurence42
Oh and its for a 2004 R53 with non xenon headlights.
Old Oct 18, 2012 | 02:12 PM
rkw's Avatar
rkw
See if it helps if you set your dash lights to maximum brightness.
The exterior lights are on fuses FL8 and FL12 in the engine compartment fusebox. They are 50 amps each and you won't find an Add-A-Circuit for it. I suppose you could run a wire from a parking or wheel arch light and run it into the cabin. Otherwise use the line you're using now to operate a relay that is connected to full 12V.
For the screws, I would go to a MINI dealer parts/service department.
Old Oct 18, 2012 | 03:43 PM
Claurence42
Ok cool, do the parking lights have their own fuse, if so could I use that and would it stay on when the headlights are?
Old Oct 18, 2012 | 06:38 PM
rkw's Avatar
rkw
No, parking lights use the same fuses as the headlights. More accurately, none of the exterior lights are directly connected to fuses. They are connected to the body control module, which is on fuses FL8 and FL12.
rtk90
Aug 29, 2019 09:08 AM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
COOPT UP
Sep 11, 2015 04:59 AM
tylewis
Sep 6, 2015 07:36 PM
Ntety
Sep 2, 2015 08:39 PM
