TPMS light On then OFF - No RESET option
Old Oct 18, 2012 | 07:14 AM
Mini2na's Avatar
Mini2na
Every time I start my '07 MINI w/OEM TMPS, I get a tire warning light on the tach and speedo display. After a few seconds they both go out, but a small warning triangle appears in the mileage display on the tach.
In the Check-Info option through the BC button, I get the tire warning symbol, but no option to reset like I have gotten before when changing wheels from summer to winter.
I have checked and double checked tire pressures and they are correct.
Are there batteries I need to replace? Is there a secret menu I need to find? I have done a reset before, but the option does not seem to be there anymore. Help please.
Old Oct 18, 2012 | 09:09 AM
bmwr606's Avatar
bmwr606
there are batteries in the wheel unit, they are not replaceable and the life expectancy is 5-7 years
after the batteries go, you must replace the wheel units
scott
edit: i asked the parts guy at the dealer ti show me the tpms sender unit, it appears they have some "watch/hearing aid" style batteries potted in, with enough time and patience, they probably could be replaced and repotted
Old Oct 18, 2012 | 09:20 AM
jhull413's Avatar
jhull413
I just got my new winter tires and wheels with TPMS from Tire Rack yesterday. This made me start wondering how they got power to send the signal. Now I know. Thanks.
Old Oct 18, 2012 | 10:40 AM
Mini2na's Avatar
Mini2na
Has anyone replaced these batteries? I sure don't want to purchase new ones.
So, the odd TPMS alerts are because of one or more batteries being dead? If I put on wheels without TPMS units in them, the alert comes on and stays on.
If I attempt this, will I have to worry about the seal on the unit itself. I know I will have to replace the valve to wheel seal.
Soldering/spot welding batteries?
Old Oct 18, 2012 | 10:54 AM
bmwr606's Avatar
bmwr606
i have replaced potted batteries in other things before, it is not easy to get the potting material out without damaging the componets within, it is a slow painstaking process
i would say you are better off buying new from tirerack or other aftermarket source
you can get them from the dealer too, for about double the price of tirerack
scott
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
quality_sound
Aug 7, 2015 09:36 AM
