First tank only 89
Old Oct 15, 2012 | 04:33 PM
Misujo's Avatar
Misujo
First tank only 89
On the way home from the dealer where i bought my used (only 16,000 miles; can you beleive it! CARFAX verified, it is a gem) 2003 S model we needed gas. We were in a hurry and i guessed 89 would be ok. Shortly thereafter it started to knock some. I checked the manual and now realize it needs 91. Oops. Will everything be ok after a tank or two?? Any ideas?
Old Oct 15, 2012 | 05:06 PM
MarinePMI's Avatar
MarinePMI
Just pour a bottle of octane booster in; problem solved. It shouldn't hurt it, if you don't do it all the time (put 89 in that is).
BTW, welcome to NAM!
Old Oct 15, 2012 | 05:08 PM
ZippyNH's Avatar
ZippyNH
Drive the car gently, and top it off with the best octane you can find...maybe a can of octane boost.
a ping is usually ok, a knock/detonation is a bigger issue....
Only time will tell if you burnt a valve or something, but a onetime use is unlikly to be an issue.
Old Oct 15, 2012 | 05:19 PM
Misujo's Avatar
Misujo
Thanks for the quick response! We will post pics soon!
Old Oct 22, 2012 | 03:39 PM
CloudStrife's Avatar
CloudStrife
Not to thread jack, but is a octane booster a treat for your car even if you use 93 regularly?
Old Oct 22, 2012 | 03:46 PM
MossMINI's Avatar
MossMINI
Hi Cloudstrife,
Your MINI's ECU will actually work to de-tune out the extra octane. To use octane boost on top of 93 octane is actually detrimental to your engine... Not a treat. Hope this helps and happy motoring!
Chris
Old Oct 22, 2012 | 04:04 PM
Capt_bj's Avatar
Capt_bj
Originally Posted by MossMINI
Hi Cloudstrife,
Chris
ummmmm ... while paying for extra octane is a waste of money please tell us why it is detrimental to the engine ..... to anything other than the wallet.
Running too low octane requires the engine to adjust to prevent pre-ignition. Extra high octane won't pre-ignite (causing knock) so what exactly does the computer do / what's wrong?
to OP
ever take chemistry in HS or college? Google 'octane' and get a basic understanding of what this term means. THEN you'll be able to draw your own conclusions. (from chemistry and internal combustion engine points of view, the Wiki write up AIN'T bad.)
I'm not an engineer but I slept in a Holiday Inn once.
Old Oct 23, 2012 | 04:51 PM
Capt_bj's Avatar
Capt_bj
waiting . . . .
Old Oct 23, 2012 | 06:28 PM
ColinGreene's Avatar
ColinGreene
if its pinging its knocking.
And thats never good. just put 91 in it next time. drive it easy till you empty the tank.
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
