Rays Volk TE37 on MINI Cooper
Old Oct 7, 2012 | 12:28 PM
muttbear's Avatar
muttbear
Hi everyone,
I would just like to ask experts/seniors here regarding installation of VOLK TE37 17 inch, 7.5 , offset 40 rims to MINI JCW Cooper 2009. What are the things I would need to install it to my car (wheel spacers/changing lugs to studs, hub centric rings, etc). What size of spacer/ lug conversion kit I will need? I cannot do a trial and error method for I am living in an area where car accessories/supply is very scarce. Im only ordering online once I confirm the exact specs of what i need.
Hope to hear from you guys.
Thanks...
PS: If anyone has installed it on their MINI, I would appreciate it if you can post pics.
Old Oct 7, 2012 | 01:12 PM
Creeve's Avatar
Creeve
You don't need anything other than tires, pressure sensors and valve stems
Old Oct 7, 2012 | 03:00 PM
ra2fanatic's Avatar
ra2fanatic
I have Volk CE28N's in 17x17.5 +43. Unless you have the Stoptech, Brembo, or even the JCW big brake kits, you don't need spacers or anything. If you do, all you'll need are H&R 5mm spacers.
Depending on bore size, you will need hubcentric spacers and most likely M14 to M12 studs to get it mounted since the holes are so tiny for M12 bolts.
Old Oct 9, 2012 | 03:58 AM
muttbear's Avatar
muttbear
Thanks Creeve and ra2fanatic for the inputs.
Does anyone know where I can source hub centric ring with 56.1/65 size? I usually see specs with 56.1/65.1.
Happy motoring ....
Old Oct 9, 2012 | 04:38 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Tire Rack... Get the aluminum ones, not the plastic.
Old Oct 9, 2012 | 07:25 AM
MiniBOL's Avatar
MiniBOL
Here's a photo on a DS MINI
Old Oct 9, 2012 | 07:33 AM
muttbear's Avatar
muttbear
Te 37
Sir MINIbol,
Can you please specify what were the things you did to install your rims to MINI?
Im confused with the lug conversion kit. Did you use spacers? What size tires you used?
Very nice car sir.
Thanks for the pic.
Old Oct 9, 2012 | 07:44 AM
MiniBOL's Avatar
MiniBOL
Originally Posted by muttbear
Sir MINIbol,
Very nice car sir.
Thanks for the pic.
I only posted a pic of my friends MINI with the wheels from your initial post. He's moved on from the MINI but maybe you can still reach him on here. User name is robspec. He may still be selling the wheels too.
Sorry I couldn't be of more help my friend.
Old Oct 9, 2012 | 07:50 AM
ra2fanatic's Avatar
ra2fanatic
Sir MINIbol,
Very nice car sir.
Thanks for the pic.
Yeah, that's Robspec's R56. He has both his sets of TE37 for sale, but both offsets on his R56 are not really good for track use. If you're just using them as dailies, then they're great, but the offset isn't that good for track use, only for stance.
Old Oct 9, 2012 | 08:11 AM
MiniBOL's Avatar
MiniBOL
I've been wanting either one if em since he's put them for sale. I told him if he still has one set by tax refund time, I'll be giving him a call. hahaha
Old Oct 9, 2012 | 08:27 AM
ra2fanatic's Avatar
ra2fanatic
I was going to get his gray set, but then I got these CE28N's. I think I got a better deal and a better set since I can run some aggressive tires w/o rubbing.
Old Nov 26, 2012 | 02:37 AM
muttbear's Avatar
muttbear
Thanks for all the insights...
TE37 Installed on my JCW...
Old Nov 26, 2012 | 05:30 AM
Braminator's Avatar
Braminator
Looks great. What did they weigh?
Old Nov 26, 2012 | 05:44 AM
submitaweasel's Avatar
submitaweasel
love those volks. I could just never afford them Looks great!
Old Nov 26, 2012 | 02:04 PM
muttbear's Avatar
muttbear
Braminator - weight is 6.5kg/rim
submitaweasel - Thanks. Took me sometime to acquire these rims also...
Old Sep 15, 2013 | 11:39 PM
edwkmho's Avatar
edwkmho
Dear Muttbear,
What tire size on on your JCW with TE37?
I am currently on original tires 205/45R17, looking for 215/45R17 or 215/40R17. But 215/40R17 hard to come by in Malaysia and Singapore.
Old Jul 10, 2014 | 07:46 PM
Jamaica2G's Avatar
Jamaica2G
I know I am resurrecting this from the dead...
JUST TO CONFIRM
If I have a JCW R56, Ideally I would need 17X7.5 +38 sizes/offsets, correct?
Adrian
Old Jul 10, 2014 | 10:15 PM
ra2fanatic's Avatar
ra2fanatic
Yeah, pretty much.
Old Feb 16, 2018 | 06:36 AM
Ruga's Avatar
Ruga
Hi mini people! I have mini cooper JCW 2008. And now i want to install wheels in next specs: r18/8j/et33. What you think about it!?
http://aniku.ru/fulllist?id=214 - wheels
https://www.drive2.ru/r/mini/475578362505462660/ - my car.
Old Feb 16, 2018 | 01:40 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
What does your question have to do with Volk TE37 wheel? TE37 doesn't come in 4x100 bolt pattern for your MINI. If asking about wheel fitment then start a new thread.
For 2008 OEM wheel size 18x7" et42
compared to your 18x8" et33
Your wheel will be 3.7mm closer to inner suspension (should be fine) and poke out 21.7mm more which is quite a bit.
What suspension are you using? Lowered suspension gives less clearance for wide wheels and tires.
What tire size were you going to use and which tire?
Old Feb 17, 2018 | 01:22 PM
Ruga's Avatar
Ruga
Thanks for the answer! Yes, maybe i must to start a new thread)
Old Feb 17, 2018 | 04:51 PM
Bnourai's Avatar
Bnourai
I have a 2009 with 16x8 et33 205/45/16's on coils and no rubbing.
Old Feb 18, 2018 | 04:17 AM
Ruga's Avatar
Ruga
Hi! Can you show me the photo!?)
Old Feb 18, 2018 | 02:15 PM
minihune's Avatar
minihune
205/45-16 fits wheels 6.5-7.5" wide, perfect for 7" wide rim, tire diameter is small at 23.3" or 1" less than OEM.
Tire selection is not that good in that size, other tire sizes for 16x8" wheels tend to be taller than OEM at 24.9".
Smaller tire diameter gives more room for clearance with wide wheel and lowered suspension. Tall tire not as good for clearance when wide wheel is used but fully adjustable coilovers can be helpful for custom fit for no rubbing.
jrezzo
Aug 9, 2015 10:32 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
