Newby with aux water pump question.
Old Oct 6, 2012 | 09:04 AM
axg1040's Avatar
axg1040
Just purchased a new to me 2010 Clubman S. It has already had the water pump recall done. Only thing I am not sure about is that sometimes I hear the aux pump run after I shut down and other times I don't. Is the aux water pump run time and or use of the pump based on temp or driving conditions? Just wanted to make sure no issues. Thanks.
Old Oct 6, 2012 | 09:09 AM
bmwr606's Avatar
bmwr606
sounds normal to me
my cms all4 aux pump will run after shutdown when the ambiant air temp is high
or
if i am driving agressively just before shutdown
if i drive gentlely for a mile or 2 before shutdown, the fan runtime is greatly reduced or it does not run at all
now that the ambiant temps are cooler, the fan runs much less than when it was 90F+
scott
Old Oct 6, 2012 | 11:00 AM
Benibiker's Avatar
Benibiker
My aux pump runs every time after shutdown regardless of outside temp. It's supposed to, it has to cool down the turbo which will get super hot no matter the outside temp.
Old Oct 6, 2012 | 04:47 PM
axg1040's Avatar
axg1040
So if you back your car out of the garage or move it a few feet after it sat over night does the aux water pump still run when you shut it down?
Old Oct 6, 2012 | 09:52 PM
Benibiker's Avatar
Benibiker
No, it has to reach operating temperature, then it'll run every time.
patsum
26
May 29, 2021 06:29 PM
one73ronin
23
Sep 22, 2015 09:56 AM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
