R56 Headlight help???
Old Oct 2, 2012 | 05:58 PM
The Angry Pumkin's Avatar
The Angry Pumkin
Headlight help???
I have a 2013 Justa w/ the stock headlights(non HID). Lets just say they are not the best I have ever seen. So just want to see what everyone else used and what worked better. Also what type of bulbs are in the head lights and fogs?
Old Oct 2, 2012 | 11:50 PM
slinger688's Avatar
slinger688
Are those h13s? I have not found too many cheap and good alternatives. Ended up with Phillips bulbs but still don't like them.
Old Oct 7, 2012 | 09:00 AM
The Angry Pumkin
Someone has to of found some thong better than the stock bulbs???
Old Oct 7, 2012 | 09:08 AM
Dr.Fox's Avatar
Dr.Fox
Try Hoen Xenon-match - I've had personal experience with them. They are about as good as halogen gets.
Old Oct 7, 2012 | 01:36 PM
Capt_bj's Avatar
Capt_bj
all your bulb sizes can be found in the owner's manual and are available at most auto supply stores. Nothing is "MINI unique"
for example, page 158 of the 2011 owners manual
Halogen low-beam and high-beam
headlights
H4 bulb, 60/55 watts
pg 160
Changing fog light bulb
H8 bulb, 35 watts
when I was unhappy with the headlights on my 02-S I put in SilverStars and was very happy with the improvement.
Note that there are several different SilverStar 'models' with their Ultra claiming the most output. You can probably find these in any decent auto part store
Over the years folks here have sometimes complained about Silverstar, esp wrt short life but mine lasted for 4 years at which point I sold the car. I was happy enough with them in the MINI to subsequently switch in my Honda and Miata too..... ULTRA's go on 'sale' routinely
The sylv' site does not list a SilverStar in H8 size tho. They do have a 'standard bulb' in that size but no reason to suspect it is much brighter.
Old Oct 8, 2012 | 06:52 PM
The Angry Pumkin
The auto parts store was unable to look up anything for a 2013....or 2012 .....or 2011.... or 2010 LOL
Old Oct 8, 2012 | 07:10 PM
Eddie07S's Avatar
Eddie07S
Try aiming the lights down a little and a little outboard for each light (that is, the driver side aimed a little more left and the passenger side a little more right). The lights on my wife's '04 are about the best I have ever had on a car. For some reason BMW changed the design with the Gen 2 MINI and made them worse. My '07 had terrible lights, but it helped a lot when I re-aimed them. For some reason the lights on my 2012 are really pretty good; still not as good as the '04's, but good.
Old Oct 8, 2012 | 07:23 PM
Jayoni's Avatar
Jayoni
I bought an after market hid set, with error code cancellers. Everything is plug and play, and I snugged everything into the headlamps. I went with hi-lo setup and not bi-xenon, so i did not have to drill holes and connect relay to the battery. The light output is great. The problem is our headlamp is reflector design, not projector design, thus the light pattern is more scattered, feel less bright.!!
Old Oct 19, 2012 | 11:37 AM
walk0080's Avatar
walk0080
Old Oct 19, 2012 | 11:55 AM
Jayoni's Avatar
Jayoni
Yes, agree stay with 43k OEM color.
Old Oct 20, 2012 | 03:02 PM
Dr.Fox's Avatar
Dr.Fox
I love my 5000k HID bulbs. Pure white.
Old Oct 20, 2012 | 09:02 PM
RJKimbell's Avatar
RJKimbell
Check out the PIAA website you should be able to find whst you are looking for. I rrplacef Molly's Head, Fog, and Parking Lights with PIAA Xtreme White Plus, liked them so much also replaced HL & FG in my Husband's Kia Soul and after an over 3,000+mi. Vacation I'm so glad we did!!
Old Oct 21, 2012 | 04:40 AM
dustint's Avatar
dustint
Yup, the Xenons are great.
Old Oct 21, 2012 | 04:54 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sylvania Automotive Bulb Replacement Guide
Old Oct 21, 2012 | 05:36 AM
thereisnosubstitute's Avatar
thereisnosubstitute
I have Xenons in my MCS but I have H4s in my 911sc using 80/100w bulbs: they are super bright, I do not overrun the lights and they do not negatively effect on-coming traffic.
I did upgrade the headlight relay however I do not know if the relay kit will fit the Mini so best to ask a part's specialist.
Old Oct 22, 2012 | 10:22 AM
C4RACER's Avatar
C4RACER
I had a bulb burn out so replaced both with a set of PIAA extreme white and pretty happy with the result. Not as good as HID, but better than the OEM bulbs for sure. TireRack sells them for $59 a set right now which isn't bad.
OutMotoring
Mar 3, 2017 06:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
