Leak in oil supply line to turbo
Old Sep 17, 2012 | 06:24 AM
Scooter162's Avatar
Scooter162
I've got a leak in my upper oil supply line to the turbo. I tried to tighten it, but it would not budge. It seems to have shown up after the recall for the aux water pump was done. My mini is a 07 MCS with 71,000 miles. any thoughts?
Old Sep 17, 2012 | 09:57 AM
jcauseyfd's Avatar
jcauseyfd
Use the search, Scooter, use the search. [<-- in the voice of Obi-Wan Kenobi]
Old Sep 17, 2012 | 10:00 AM
hudub's Avatar
hudub
This is a pretty common problem and really should be a recall IMO. The line uses a rubber gasket for the seal on the turbo end and after many heat cycles that gasket deteriorates. My friend has a WRX and subraru also did a recall on their turbo lines for this exact same problem, no peep from Mini though.
I've got a 07 R56 and just recently noticed oil stains on mine as well, just over 50k miles. The solution is to replace with an aftermarket line that does not use the rubber gasket. Detroit Tuning makes one. I am planning to do a post soon on all the information I've found related to this issue. I am hoping to do it myself as the dealer wants $1k just for labor to install this $60 line.
Old Sep 17, 2012 | 10:57 AM
sooper_cooper's Avatar
sooper_cooper
This is a fairly common problem. I had it happen to my car and the dealer fixed it under warranty. Since they replaced the hose with stock parts I won't be surprised if it happens again.
Old Sep 17, 2012 | 12:53 PM
Scooter162's Avatar
Scooter162
Thanx, I did look after I posted and found the bad news. I might try to tackle this myself with aftermarket lines.
Old Sep 18, 2012 | 09:31 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We make a fix for it. There is a link for the install directions there also.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Sep 18, 2012 | 11:20 AM
Scooter162's Avatar
Scooter162
Thanx Chad, I was already looking at your kit, and DT is highly spoken of by the members of our group.
Old Sep 21, 2012 | 08:28 AM
Everyday I'm Motorin's Avatar
Let me know if you have any questions. I just went through this whole scenario myself.
Old Sep 21, 2012 | 09:41 AM
Scooter162's Avatar
Scooter162
Thanx, I found your post after I did this one and followed it. It will help out tremendously when of if I do it. Unless you feel like motering up to Omaha Ne and going through the nightmare all over again.
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
patrioticmini
Aug 20, 2015 10:54 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
