First Issue...
Old Sep 14, 2012 | 10:46 AM
abdielhiram's Avatar
abdielhiram
First Issue...
Hi All
Thanks in advance for any help I can receive.
Here is the problem...
Yesterday I used the car about 1 hour, and then about 4:00PM Local time, I stopped the car to buy some stuff....
Noticed the Fan stayed on.
I thought it was normal, and then went to the store, and probably spent like 7 - 10 Mins... and the fan was still on..
I turned the Key and then turned back to the off position and the fan came off...
When I got home that didn't happened.
Now, couple of minutes ago, wife called in concerned about the same issue, the Temp gauge is OK right in the middle, I haven;t checked the coolant level...
I read some threads here about this issue, and I am going to purchase the Fan relay initially to see if that corrects the problem...
Any other advise?
Old Sep 14, 2012 | 04:09 PM
abdielhiram
Well I replaced the 2 Fan Relays in the Fuse Box... I went to the stealer and they said is usually normal.. just annoying I guess..
hope to hear comments..
Old Sep 14, 2012 | 05:51 PM
Eric_Rowland's Avatar
Eric_Rowland
Hmmmm. Can't say as I recall the relays failing as the cause of the fan staying on... But let us know if that solves the issue.
Old Sep 14, 2012 | 06:52 PM
abdielhiram
I am monitoring the behavior... My doubt is more if it´s normal at all?
Old Sep 15, 2012 | 03:13 AM
jwh's Avatar
jwh
This happens on my 2003 R50 if the coolant level is even a little low in the overflow tank. It's normal for the fan to stay on for a minute after you shut off the engine when it's hot out or you were running the A/C but after a few minutes the battery will be drained. That's not normal.
Check the coolant level and top it off if it's low. That does it for me. I check it every time I fill up the gas.
iamcamkeenan
Aug 10, 2015 03:31 PM
nicholasterry
May 30, 2015 03:35 PM
Grizld700
Apr 10, 2015 10:10 AM
Paul830
14
Feb 1, 2003 05:35 PM
