R50/53 Tach signal??
Old Sep 11, 2012 | 02:45 PM
jwconnexion's Avatar
jwconnexion
Tach signal??
update: so I figured the tach signal is coming from the ECU. Searched the forum and couldn't find ECU wire diagram...
update: got it working except tach signal wire.. so unit is registering rpm but need tach signal(miles/h). any thoughts?
Recently purchased Defi zd csp and need help with wiring.
+Defi control unit
1. Red: +B(Battery: to 12v battery wire)
2. Orange: IGN(Ignition: to 12v wire while ignition is on)
3. Black: GND(ground)
4. White: +ILM(Illumination: to 12v wire small light is on)
+Defi ZD unit
5. Green wire: for Speed signal (rpm)
6. Blue wire: for tachometer signal (miles/h)
2006 r53 jcw
1. Red w/ blue tracer w/ yellow hatches (obd2)
2. Green w/ blue tracer w/ yellow hatches (under steering wheel column)
3. Brown
4. Grey wire with red tracer (tach wire)
5. White with red tracer (obd2)
6. ??
reference
http://www.defi-shop.com/media/zd_manual_1202-1_e.pdf
http://www.defi-shop.com/media/acu_manual_1112-1_e.pdf
http://www.altaperformance.com/share...ampinr205b.pdf
Thanks guys!
Old Sep 11, 2012 | 03:52 PM
rkw's Avatar
rkw
Don't you have that backwards? Speed is miles/h and tachometer is rpm.
The installation instructions for the FES Shift Light describes both wires. Download the Users Manual on this page: http://www.fes-auto.com/products_detail.php?productid=6
Old Sep 11, 2012 | 06:06 PM
jwconnexion
rkw, you are Awesome! Exactly what I am looking for!
For some reason Defi Manual reads Speed signal as RPM. Not sure why.
I wonder if this wire extends to somewhere near the steering column..
I will post some pics when complete.
Thanks!
PsychoRallye
21
Feb 17, 2019 06:08 AM
Scm68
Jan 27, 2016 12:33 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
