Rough idle/stumble from cold start
Old Sep 4, 2012 | 04:23 AM
wolfe's Avatar
wolfe
We're seeing a concerning issue with our '07 R56 cooper S (automatic, 75k miles).
We aren't getting the noise associated with the tensioner failure (it did have this noise, and was fixed under warranty a couple of years ago).
It does this most noticeably on a cold start but will do it from a warm start to some extent.
The power delivery and idle stumbles at low rpm. It almost sounds like a misfire (no CEL). It doesn't ever seem to stall though it comes close.
When you start driving slowly from cold you can feel the surging, which seems to improve once warmed up.
It's had new oem spark plugs at about 70k, and all other maintenance is up to date. It's never had the walnut shell blasting.
The only odd thing which may or may not be worth mentioning is the camshaft visible through the oil fill hole has a visible pattern to it on the lobes, almost like an even, repeating zigzag pattern.
Any ideas would be much appreciated.
Old Sep 4, 2012 | 04:49 AM
slinger688's Avatar
slinger688
It is quite possible you have a carbon buildup issue.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
Marco Guardado
Sep 15, 2015 01:22 AM
