Sun Damage Windshield Cowl
Old Sep 3, 2012 | 03:14 PM
OkieSnake's Avatar
OkieSnake
I guess the Oklahoma Sun is a bit destructive on my 08 MCS.
Does anyone know the part numbers and cheaper place to buy some new left and right front cowls. The car has 44K and I doubt warranty would cover the damage by the sun (I guess it was the sun). It is cracking all along the thin edge next to the windshield. Looks like it’s the whole pieces on each side that include the battery access panel and brake fluid access.
The rear MINI logo has also faded.
Old Sep 3, 2012 | 03:35 PM
bluefox280's Avatar
bluefox280
R56 --> Vehicle Trim --> Exterior Trim --> Windsheild Frame Cover:
Item #03 - Left Apron Cover (#51132751209)
Item #04 - Right Apron Cover (#51132751210)
R56 --> Vehicle Trim --> Exterior Trim --> Emblems / Letterings
Item #02 - Emblem REAR (#51147026186)
- Erik
Old Sep 3, 2012 | 03:45 PM
CR&PW&JB's Avatar
CR&PW&JB
Cheapest price I found for the rear Wings badge was on EBay. Seller is a dealership... Prestige MINI. In New Jersey, I believe.
Old Sep 3, 2012 | 04:58 PM
OkieSnake's Avatar
OkieSnake
Bluefox280, Thanks for the part numbers! Thats what I needed.
CR&PW&JB, thanks for the tip.
Old Sep 5, 2012 | 09:36 AM
ENEMINI's Avatar
ENEMINI
You think OK sun is harsh, try high altitude sun here in CO!
I just noticed this on mine as well when the windscreen was replaced. Pretty cheap part actually, and easy to install.
Old Sep 5, 2012 | 11:09 AM
texasmontego's Avatar
texasmontego
Happens in Houston too. I try to keep mine Armor All'd, but doesn't last that long. I've always accepted the fact that the environment is going to wear on pieces that I will eventually have to replace and/or repaint. Cost of doing business is how I justify it. If you want to keep your car looking nice, sometimes you have to pay.
I've seen that piece wrapped in Carbon Fiber. Haven't seen it in person, so it's hard to tell from pictures if it looks good or too much.
Old Sep 5, 2012 | 11:30 AM
CR&PW&JB's Avatar
CR&PW&JB
Did someone say Armour All ??!!??
Old Sep 5, 2012 | 11:44 AM
sean5294's Avatar
sean5294
Im not sure what others are selling them for but we have them for $32.82 per side and the rear emblem for $22.26.
We are a supporting vendor, our site is http://www.theminipartstore.com/
If you have any questions shoot me a message!
Old Sep 16, 2012 | 05:57 AM
xcelr8's Avatar
xcelr8
I found these listed for 42 per side on your site.
OkieSnake, I could not disagree with you more. Sun??? My other vehicle is a 2000 with 60,000 miles and there is zero cracking fading peeling. I live in Florida where everything roasts all day. This is disgusting craftsmanship plain and simple.
Old Sep 16, 2012 | 06:34 AM
CR&PW&JB's Avatar
CR&PW&JB
Could very well be due to water damage as much as UV damage. You let rain water or water from washing sit on the rubber orders plastic bits and you are asking for fading, cracking and/ or peeling.
Just curious, Omission... is your MINI garage-kept?
Old Sep 16, 2012 | 12:12 PM
TiminSoCal's Avatar
TiminSoCal
Seal strip
Isit just the rubber part?
Item 3 Seal strip?
In the pic I dont see cracked plastic.
Old Sep 16, 2012 | 09:01 PM
krim's Avatar
krim
#3 is the driver side apron (cowl), and yes, its the rubber seal.
Old Sep 17, 2012 | 02:42 PM
mikeyb74's Avatar
mikeyb74
Just replaced both apron covers in 10 mins. Bought them from Bavauto. I did not need #1 or #6 or #7. I tried to have the dealer warranty both pieces when the MCS was still warranty but they claimed it's from an ice scraper. They quoted me almost $200.00 to replace these.
the matey's Avatar
the matey
wow, my cowl did the same exact thing in the same spot!
Old Dec 6, 2012 | 02:21 PM
MyYellow 07's Avatar
MyYellow 07
Me too. Ordering replacement.
Old Dec 6, 2012 | 09:33 PM
jtack's Avatar
jtack
I knew I couldnt be the only one thinking that
Old Dec 7, 2012 | 04:55 AM
amancuso's Avatar
amancuso
I'm going to try to use the MINI vinyl and rubber treatment on those parts every other month or car wash to see if it prevents this from happening.
Old Dec 7, 2012 | 05:46 AM
jhull413's Avatar
jhull413
I noticed a hazy graying on mine after only a month or so, maybe from the glass cleaner used on the windscreen, I'm using the MINI vinyl and rubber treatment now too.
Old Dec 18, 2012 | 08:00 PM
arro's Avatar
arro
So, is there any real harm to simply trimming off the bad rubber seal?
--Arro
Austin, Tex.
Without a garage to protect it from the sun
Old Mar 24, 2013 | 07:57 AM
MeepMini's Avatar
MeepMini
Hey folks,
I have the exact same problem with my 07S. Do I need ALL those parts or just the 2 aprons? Are there any of those plastic connecters that break every time you try to remove them? Also, does anyone know where I can find a DIY manual for that?
Old Mar 24, 2013 | 11:13 AM
wac's Avatar
wac
Lol !! Looks like mine too. Same spot !
Old Mar 24, 2013 | 05:09 PM
Porthos's Avatar
Porthos
These things are super easy to install plus even buying them from the dealership is not expensive. I just replaced mine about 2 months ago. They are around $0 for each side. Also might as well replace them together because it will look wierd with one new and one old.
Old Mar 25, 2013 | 09:29 AM
+1 for the replacement together. Otherwise you will have one that looks allot newer then the other side.
Here is the pics the check them out. Comes with the cover flaps for the battery and the brake fluid access panel.
Plastic nut and hex bolt mounts to the outer side to hold in place. #8 and #7 which you can undo the ones you have and re-install in its place.
http://www.ecstuning.com/Search/51132751210/
Old Mar 25, 2013 | 10:41 PM
El Zilcho's Avatar
El Zilcho
Mine was replaced by the dealer about a month ago, no questions asked on my 09 clubman s. 40k mi.
Old Jan 2, 2014 | 07:34 AM
Dustdevil's Avatar
Dustdevil
OK Sean. I ordered the pair of apron covers from you 6 weeks ago, and I still have not received them. Can you check on the order? I replied to the order confirmation via email as well. Order information should all be there. These should have arrived a long time ago.
