Oil residue on top of valve cover
Old Sep 1, 2012 | 11:29 AM
Price's Avatar
Price
Is it normal? There are no leaks around, no abnormal oil consumption, no stains on garage floor, but it kinda bothers me as imho engine should be dry and clean unless there are leaks, i.e. repairs are needed.
Is it possible to open the top portion of the valve cover to see what's going on there?
Old Sep 1, 2012 | 03:17 PM
hydouken's Avatar
hydouken
I have the exact same thing just happen to me. I would like to know what is causing this.
I checked my oil level and it is normal.
I will clean this up today and try to see where the leak is coming from.
Old Sep 2, 2012 | 07:06 AM
bluefox280's Avatar
bluefox280
It's either a bad valve cover gasket, or there's a crack in the cover or PCV system itself.
Clean the area, and see where the seepage occurs afterwards.
- Erik
Old Sep 2, 2012 | 08:04 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
It's looking like a broken PCV valve that is built into the valve cover. you will have to replace it. Not too hard of a job really, that almost anyone could do. This is starting to be a problem on more gen 2 cars.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Sep 2, 2012 | 10:26 AM
Price's Avatar
Price
Hm, time to engage CPO, I guess. Will post updates, if any.
Old Sep 3, 2012 | 12:25 PM
WTH's Avatar
WTH
Chad
Detroit Tuned
I have the same problem with my 08 "S". Do you need to replace the gasket when you replace the cover? Where is the best place to get the cover and basket?
The dealer pricing is outrageous... Please advise.
Thanks.
Old Sep 3, 2012 | 03:28 PM
bluefox280's Avatar
bluefox280
As a rule of thumb, it's always highly recommended you replace any gasket you open up.
Besides the dealer? Not much else other than PenskeParts.com or ECSTuning.com
- Erik
Old Sep 4, 2012 | 08:30 AM
Price's Avatar
Price
passportautoparts.com seems to be a good source too.
Old Sep 4, 2012 | 08:51 AM
Detroit Tuned
Vendor - 15 Years
I'd have to get a firm price on it but $285-$300 is the norm (plus shipping). It will come with all gaskets needed. Detroit Tuned can get you any OEM MINI part for a good price, we sell everything at list. Some items are on our web but most are not, you just have to give us a call.
Chad
Detroit Tuned
Old Sep 10, 2012 | 08:27 AM
Price's Avatar
Price
Well, got cover gaskets replaced, we'll see if it was just them.
Old Sep 10, 2012 | 11:17 AM
strobeyprobey's Avatar
strobeyprobey
I've had good luck and good prices with parts.com on BMW and MINI OEM parts.
Old Dec 2, 2012 | 07:30 PM
MINeclair's Avatar
MINeclair
How are things with your valve cover since you had your gaskets replaced? Any noticeable difference? Do you think that fixed the problem? I have the same symptom on my Cooper S and was just curious.
Old Feb 17, 2013 | 07:58 AM
sripavan's Avatar
sripavan
Hi I am having the same issue on my 2008 mcs with 53000 mils. Can you please let me know if changing the gasket was enough or if you had to change the cover as well.
Thank You
Pavan
Old Feb 18, 2013 | 07:39 AM
Here is the valve cover gasket: N14 engines
OEM MINI part number: 11127572851 : Click the picture below for item.
http://www.ecstuning.com/Search/SiteSearch/11127572851/
N14 engine valve cover OEM MINI part number 11127646555
http://www.ecstuning.com/Search/11127646555/ES2601877/
If the valve cover is leaking all the way around its most likely the cover itself.
Old Feb 18, 2013 | 09:42 AM
gregsmini's Avatar
gregsmini
Hey ECS, is this valve cover redesigned or is it exactly the same as the original on my 2008 MCSm.
I'm hoping that Mini redesigned it so for my $250 bucks it traps more oil so less going through the PCV to stick to my valves!
Old Feb 18, 2013 | 10:07 AM
gregsmini - What I know is the part has a just received a newer MINI part number from the older MINI part number 11127585907 . The outside looks the same.
Old Feb 18, 2013 | 11:10 AM
sripavan's Avatar
sripavan
Thank you. I suspect the valve cover it self as its near the pcv hose on the right side where I find the residue. Thanks again for the pics and part#.
Old Feb 18, 2013 | 11:26 AM
Your welcome. Glad I can help. If you need anything else let us know.
Old Feb 18, 2013 | 01:58 PM
gregsmini's Avatar
gregsmini
Thanks! I have oil residue one the outside of my valve cover too. It might be on my to do list...but not at the top.
Old Mar 4, 2013 | 11:36 AM
sripavan's Avatar
sripavan
should I use a RTV sealant while replacing valve cover
Hi Guys,
I cant find it now but there was one thread that said Bentley suggests to use a RTV sealant. I don't have a Bentley manual so may I ask If any one used a sealant and at what places on the gasket.
Thank You
Pavan
Old Mar 16, 2013 | 07:32 AM
metro62's Avatar
metro62
I have a 2007 MCS with a suspected bad cylinder head / valve cover.
When I do an online parts lookup at MINI of South Atlanta the results show the old part number 11127585907.
Does the new design part 11127646555 fit all years of the N14 engines?
Edit: I did a search at another online parts source and the cross reference returned part 11127646555 - but any confirmation is welcome before I shell out ~$300.
Old Mar 16, 2013 | 09:18 AM
Price's Avatar
Price
Sorry for late response, but yes, new gaskets fixed the issue.
Old Mar 18, 2013 | 10:03 AM
The valve cover for the R55 R56 R57 N14 engines has been updated.
If you dump a part number into our site the super-session will show and you click on the ES# and it will take you to the new part.
The gasket is the same number as before.
http://www.ecstuning.com/Search/11127572851/
MINI Valve cover Emblem Part # 11127594876
http://www.ecstuning.com/Search/SiteSearch/11127594876/ES514833/
Oil Label sticker Part # 01000419179 ( Which is used on all MINI engine bays in multiple locations dependent on year and model )
http://www.ecstuning.com/Search/SiteSearch/01000419179/
And the little yellow ignition coil sticker looks to be part #71227618790
http://www.ecstuning.com/Search/SiteSearch/71227618790/ES2674957/
And what it look like:
Old Mar 22, 2013 | 05:05 AM
metro62's Avatar
metro62
Cover 11127646555 comes with a red ring on the rear port and an excess pressure relief valve packed in a separate ziploc bag. I assume the ring gets pulled out and the check valve put in its place, correct?
Old Mar 22, 2013 | 06:44 AM
Yes,
In the zip lock bag come the little seal / adapter you see in the pictures and the pictures have been updated.
In the bag is a little paper with instructions for the seal adapter.
Thanks and hope that helps.
