R60 Coolant temp sensor and water pump
Old Aug 25, 2012 | 09:27 AM
MiniMouse17's Avatar
MiniMouse17
Did anyone get anything about a water pump recall? And is it related to the coolant temp sensor?
I need to make an appointment to get my coolant temp sensor replaced or fixed. But dealer is in Dallas or Houston so it might be a few weeks.
Any suggestions on when I should have this done?
Thanks everyone!
Old Aug 25, 2012 | 11:01 AM
bmwr606's Avatar
bmwr606
a week ago today, i was at the dealer for "free car wash saturday" and the SA "read my key when i checked in
he found that a "recall camaign" the so called coolant sensor recall applied to my car, an 03/2012 build cms all4 manual
i have had no cels or warnings of any kind in 4 1/2 monthes and almost 6k miles of ownership
wed had the campaign performed, took 45 minutes including another free wash
i notice no change at all in the operation of the car after a little over 200 miles driven since having the campaign performed
if you are not having any issues, get the recall done at your convience, otherwise asap
scott
Old Aug 25, 2012 | 11:14 AM
bostonterrier's Avatar
bostonterrier
my quick take on this is get it done as soon as possible because once the letters go out, there may be a lot of people getting in line before you. i called as soon as i read this forum...thanks forum people!
Old Aug 25, 2012 | 11:31 AM
bmwr606's Avatar
bmwr606
my SA said they are staging the sending of the recall letters as well as staging the recall as appling when the key is read so that parts are available and a rush is avoided
i go to the dealer almost every saturday for "free car wash saturday" and they read the key at checkin, last saturday the recall showed as appling to my car, previous weeks it did not, and i have not received a letter yet
scott
Old Aug 25, 2012 | 01:20 PM
DR61's Avatar
DR61
Thanks everyone!
I believe the 'water pump recall' was for 2007-early 2011 turbo Minis and is the small pump that cools the turbo bearing, not the engine water pump. Later 2011 and all 2012 already have the new part.
Old Aug 25, 2012 | 07:26 PM
MiniMouse17
Thanks everyone, for your replies. We may not be able to make it to our dealer until middle to end of September, so that's why I'm asking about these recalls.
Old Aug 25, 2012 | 08:25 PM
beauxgoris's Avatar
beauxgoris
So no water pump recalls for '12 countryman's?
Old Aug 26, 2012 | 04:19 PM
Kimsc321's Avatar
Kimsc321
Went into the dealer last week for a scheduled oil change and they alerted me for coolant temp sensor recall - nothing about water pump....
Old Aug 26, 2012 | 07:52 PM
broussardc's Avatar
broussardc
I got mine done last week at MINI of Austin
Old Aug 27, 2012 | 06:35 PM
Koopah's Avatar
Koopah
Just for the record...
There has never been a recall for the engine water pump. There *was* a recall on the circuit board that controls the (separate) turbo cooling system. When overheated, some components of the board were prone to failure.
There is a current recall on the temperature sensor. It is in a different location on the R60 than the other MINI models. This new location is nearer to a heat source that, in some cases, melts the solder on the sensor leads causing them to disconnect. With disconnected sensor leads, the R60 wil not start.
HTH,
Old Aug 27, 2012 | 08:46 PM
adrianaq17's Avatar
adrianaq17
I emailed my SA just to double check and he told me that there is no formal recall for the sensor at this time however the part is being switched out as Countryman's come in for their yearly check.
Old Aug 27, 2012 | 09:33 PM
kunzman's Avatar
kunzman
They should do a recall, the car can leave you stranded.
Old Aug 27, 2012 | 10:43 PM
starman's Avatar
starman
https://www.northamericanmotoring.co...or-recall.html
Old Aug 28, 2012 | 09:11 AM
Rockland's Avatar
Rockland
Just got a call from my dealership asking for me to schedule an apointment to replace the coolant temp sensor.
Old Aug 28, 2012 | 02:28 PM
Koopah's Avatar
Koopah
...he told me that there is no formal recall for the sensor at this time...
Absolutely right! My bad calling it a "recall". MINI probably has issued a technical service bulletin (internal) so as to avoid an "official" (public) recall.
Old Oct 27, 2012 | 09:07 PM
trexinthecity's Avatar
trexinthecity
I have a 2012 base model mini and I was driving on the freeway and my engine light came on. I heard this rattling like a fan rubbing against plastic. I took it to the nearest mini dealer. They took my key and the cooling sensor comment came up on my work order...i left it..came back, and they mentioned something about a water pump..does that sound right for a base model? any new updates?
Also..what's up with waiting till 16,000 miles for an oil change..is that necessary...i am soooo not used to this.
trexinthecity
Old Oct 28, 2012 | 06:28 AM
FredoinSF's Avatar
FredoinSF
Originally Posted by trexinthecity
{snip}
trexinthecity
Welcome to NAM!
Do a search for oil changes and a lot will come up. Most people who are nervous about the extended oil change pay out of pocket to do them sooner. Again, searching, particularly in the forums for older models, will provide more info to ponder more so than answers and I don't want to completely derail this thread into another oil change discussion.
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
