225-45-17 V710's a good autox tire?
Old Aug 23, 2012 | 03:20 PM
C4RACER's Avatar
C4RACER
I found a good set of used V710's in 225-45-17 size.
Would this be a good choice for a DS autox car on 17x7 rims?
My only concern is height - 25" is a bit tall, where I think a more ideal size is 24" from a gearing standpoint.
Thoughts?
Old Aug 23, 2012 | 04:06 PM
ToBFree's Avatar
ToBFree
I'd stay at the 24" diameter for the reason you mention. No need to increase the need for more power to get moving.
btw, I have a nice used set of Enkei racing, lightweight, 17" x 7" wheels for sale in the Marketplace. In case you're wanting some.
Enjoy autox'ing.
Old Aug 23, 2012 | 04:09 PM
Spooled's Avatar
Spooled
If you're not doing national or regional competitions, they'll be fine. If you want to eek out everything you can, then yeah, you'd be better off with a lower profile because of the better gearing. If they're a good deal though, and local - I'd probably go for them.
Old Aug 23, 2012 | 04:31 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thoughts?
Assuming you have a stock 17x7 wheel and stock suspension you will be fine with 225/45-17 Kumho V710. Fits rims 7-8.5" wide, $232 each when new. Since they are used it's likely that tread wear makes them a little less tall.
Old Aug 23, 2012 | 04:45 PM
C4RACER's Avatar
C4RACER
oh true - probably they came shaved too, so that would make them less than .5" taller than stock which is probably not a major deal.
Old Aug 23, 2012 | 05:04 PM
minihune's Avatar
minihune
Rubber wears fast on the track.
If the used tires were for autocross they were likely not shaved.
For those tires most likely there were heat cycled on a roller before use then lightly scrubbed in before competition or first use.
If they look fairly smooth and even in color then great.
If they have a very pebbly surface or there are multiple color shades on the tread areas they are worn out.
Old Aug 23, 2012 | 05:05 PM
Jim Michaels's Avatar
Jim Michaels
New V710s come at 4/32" tread depth, so probably weren't shaved.
Old Aug 23, 2012 | 05:15 PM
C4RACER's Avatar
C4RACER
Ah - got it. Well, from the looks they are down about half tread then which is where they start working well. Supposedly only 6 20min HPDE sessions on them
Old Aug 24, 2012 | 04:46 PM
C4RACER's Avatar
C4RACER
Wow - turns out it was harder to find a suitable light 17x7 wheel with 42mm+ offset than I thought. So that makes these tires a lot less interesting.
I can get a 225-50-16 new R compound BFG-R1-S or Hankook 214's plus some 14-15lb wheels for the same overall cost and save 3lbs plus 0.5" shorter sidewall which should work better.
Old Aug 24, 2012 | 05:21 PM
Jim Michaels
Tire Rack carries several 17X7" light-weight wheels with ET 43 or 42. See, for example, Enkei Racing RPF1 (14.6#; $216) and Kosel K1 TS (15#; $196).
Old Aug 24, 2012 | 08:34 PM
Btwyx's Avatar
Btwyx
We got some RPF1s for our track wheels, they seem quite reasonable.
Old Aug 25, 2012 | 08:38 AM
C4RACER's Avatar
C4RACER
Right - I can either get $800 wheels and the used $500 tires with 17's, or I can get $500 14# 16" wheels and new $800 tires. Overall the 16's will be lighter and have the same footprint, plus then I have new tires. So that seems like the way to go.
ebowling
90
Aug 4, 2019 09:15 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
StuRat
Aug 24, 2015 06:24 PM
nomar116
Aug 10, 2015 11:24 PM
