R50/53 How do I remove this shifter cable? (Pic)
Old Aug 22, 2012 | 04:30 PM
firetruck41's Avatar
firetruck41
I am trying to figure out how to remove this cable from the transmission on my 02 base Cooper. I removed the other cable which looked "conventional" and did not have this metal contraption surrounding it.
Do I just pry it off, the same as the other shifter cable, or am I supposed to remove the metal casing first? If so, how?
Thanks for any help!
Attached Thumbnails How do I remove this shifter cable?  (Pic)-shifter-cable.jpg
Old Aug 22, 2012 | 07:30 PM
firetruck41
I figured it out, it just had to be pried off, the same as the other cable. I actually used a pickle fork, as it was hard to do it with screwdrivers, and I had already removed the clutch slave cylinder and bracket, so I had plenty of room for the pickle fork, from the front.
Old Feb 28, 2023 | 06:18 AM
vdotpdotcom's Avatar
vdotpdotcom
Help needed firetruck41 please if you are still active
That rectangle shaped end, what is it called? Mine keeps popping off and the gears go floppy. Do you have to change the whole lot or can I change just that solver rectangle piece in your picture?
Any help will be much appreciated. Thank you
IQRaceworks
Jan 13, 2017 10:01 AM
JRhea
Dec 16, 2015 12:58 PM
mkoutnik
Jun 11, 2014 05:34 AM
Odell
Feb 24, 2011 05:50 AM
