R50/53 OBC question, consumption, speed
Old Aug 22, 2012 | 07:27 AM
mini cro's Avatar
mini cro
Hi,
i managed to put the OBC stalk in the car and coded the OBC feature through bmw dis.
In my first cooper i had the same stalk, but it showed me speed on small screen on the revolution gauge. is it possible to get it coded in this car also?
And another question regarding the consumption shown on the same small screen. It doesnt show me the actual current consumption, instead of that it shows me every like 2km a different value. i want to know if this is like in every other mini, or should it show instant consumption? Because when i did a reset on the ecu, for around half an hour it did show me instant consumption, the moment i turned the car off and back on again, it started showing the consumption after every 2km or so..
Every help would be highly appreciated, and thanks in advance
Old Aug 22, 2012 | 07:50 AM
leaf_fan_1988's Avatar
leaf_fan_1988
You can do this? Where can I get an OBC stalk like that?
Also I bought a dual cluster gauge from someone that used to have a 2006 mini S (I have a 05 justa) the gauge has the RPM like all mini's and then right next to it, identical size it has a smaller version of the speedo with the turn signals and other engine lights on it.
So plug and play, only the speedo needle moves, none of the lights work. is there away I can get it all to work as well?
Old Aug 22, 2012 | 08:21 AM
submitaweasel's Avatar
submitaweasel
Originally Posted by mini cro
Hi,
I've got the choice of vehicle speed, outside air temp, avg cons., inst. cons. (which does update constantly), and average speed, all of which I can cycle through with a button on the stalk. That's the way that mine came from the factory..
Old Aug 22, 2012 | 10:28 AM
mini cro's Avatar
mini cro
ofcourse, i did have to buy the wiring, but it costs like 20 dollars or so, and ill give you the code which you could give to your local dealer and then order it.
I got mine from ebay, it was like 10 dollars..i think.
i suppose that you have the one on the picture below? or navigation?
http://www.blimeycabrio.com/wp-conte...ono_before.jpg
anyway, you would have to code it to your car, i think it comes with the chrono package..anyway, they would have to code it or you could do it by yourself if you know how and have the cables and software.
hmm i dont know if it maybe came as an option on minis above 03, but my first one was 04.. it had then the outside temp and speed, but no consumption, average speed, consumption both the average and instant, range..
this one is 03 and i retrofitted the obc feature, but i have the range, outside temp, average speed and consumption, but the average speed is always around 40kmh, and the consumption isnt the instant one, nor the average one.. any ideas?
Old Aug 22, 2012 | 10:40 AM
leaf_fan_1988
No, that's, not the one I have. In fact that one is pretty ugly. This is what I have http://www.fes-auto.com/upload/image...plit%20400.jpg
How much do you think they charge to code it? I don't have cables or software.
Old Aug 22, 2012 | 10:41 AM
leaf_fan_1988
And please do share the obc stalk info
Old Aug 22, 2012 | 04:02 PM
submitaweasel
I believe that's known as the "Chrono Pack." That's all I know.
As for if the consuption, etc, is an option or not, I have no idea. I do know my MINI was fitted with most factory options, less the sat nav, LSD, auto headlights and rear fogs.
Old Aug 23, 2012 | 01:12 AM
mini cro's Avatar
mini cro
62 13 0 029 492 - RETROFIT KIT ,ON-BOARD COMPUTER
The parts that are in the kit are as follows
01 29 0 017 969 -stick-on label
51 11 7 043 435 - bracket for temperature sensor
51 43 7 048 911 - clip natur
61 12 0 140 552 - retrofit cable set, on-borad computer
61 13 1 367 599 - cable strap
61 31 1 484 333 - switch turn signal, clip-dim control
65 81 6 905 133 - temperature sensor
and it also should include installation instructions.
I dont know the correct price of each item, but you could look it up here:
http://www.bmwetk.com/parts-catalog/.../2002/06/48020
dont know if there are differences in parts between 02 and 05, but you should perform a search based on your VIN and then list all the parts and prices.
Hope it helped
Old Aug 23, 2012 | 05:18 AM
submitaweasel
That link didn't work for me when I tried, but I just plugged my VIN into the NAM decoder and one of the interior options on the list is: " Instrumentation-inc: tachometer, outside temp gauge, speedometer, LCD odometer/tripmeter, fuel/" (Safe to presume it would go on to list the other features described here if it had more space).
Edit: Just came across this as well...unrelated but I didn't know this: " Lockable climate controlled glove box"
Old Aug 23, 2012 | 05:33 AM
mini cro's Avatar
mini cro
no no, this is the site where you will find parts, their prices and their codes so you know what to order from the dealer. this doesnt list your car options, it just adjusts the search criteria to a specific model. it does state the basic info, wether its LHD or RHD, and things like that
Old Aug 23, 2012 | 05:40 AM
submitaweasel
That's what I was figuring the link was for. I just wanted to play around and see what parts it said was for my 06.
Old Apr 20, 2013 | 07:58 AM
scottwrightF1's Avatar
scottwrightF1
Hope it helped
I am interested in doing the setup. I have the temperature already in my 2002 MC. So I would just get individual parts to setup for the retrofit, but I do not see wiring parts in the list? What is the parts number for the wiring setup? I am assuming this is the part number #61 12 0 140 552, but this is from Europe. Will it work in North American?
The only thing I would need to get from www.pelicanparts.com:
62 13 0 029 492 - RETROFIT KIT ,ON-BOARD COMPUTER (Is this the gauge or the switch turn signal?)
Could I use my stock gauge RPM on top of the steering wheel #62116913667 and will it work or do I need a different gauge? What is the part number?
The rest I have spare parts such as cable straps and clip natur.
Is there anything else I am missing?
Please let me know.
Thanks.
Old Apr 22, 2013 | 08:54 PM
scottwrightF1
Please let me know.
Thanks.
No one?
silence2-38554
Nov 12, 2015 09:39 AM
M7Speed
Aug 18, 2015 05:18 AM
M7Speed
Aug 14, 2015 01:50 PM
M7Speed
Aug 14, 2015 01:46 PM
