Joystick Problem
Old Aug 21, 2012 | 07:17 AM
shark715's Avatar
shark715
Joystick Problem
We have had our CM for three months now. I noticed from the very beginning that when you depress the joystick you have to press it down much harder than I what I would think to be normal...otherwise nothing happens and it's as if you did not press it at all. Anyone else have the same complaint/ observation? I searched the forum for similar complaints and the only thing I could find was an R56 owner whose joystick would get stuck in the depressed position. The dealer lubed it and solved the issue. Thanks in advance for your input.
Old Aug 21, 2012 | 08:22 AM
noreen99's Avatar
noreen99
Same here sometimes it takes a couple tries to get it to work
Old Aug 21, 2012 | 08:43 AM
shark715's Avatar
shark715
Thanks for your response Noreen. How old is your car? Has it been this way since new?
Old Aug 21, 2012 | 08:53 AM
noreen99's Avatar
noreen99
2012 March build took delivery end of April. Although I've already been in for my first service ( forgot to ask because I was really frustrated with service dept) taking it in (differnt dealer)for check up before we drive to Mickey & MINI, let you know what they say.
Old Aug 21, 2012 | 09:07 AM
shark715's Avatar
shark715
thank you
Old Aug 25, 2012 | 07:35 AM
Rktcyntst's Avatar
Rktcyntst
I've got the same issue in my 2012 CM. Need to "press with authority" to make a selection.
My wife has a 2012 R57 w/ Connected, but hers seems to act as you'd expect: gentle press & selection is made.
I've not made mention of this to service since I've gotten used to the press and I'm more concerned they'd break additional stuff vs. just fix what I've got now if an attempt was made. That and it doesn't bug me since I'm used to it now.
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
