Racing 17 inch tires?
Old Mar 22, 2004 | 06:17 PM
MSFITOY's Avatar
MSFITOY
Is there such a thing for the Mini? Is there a dry weather, R compound available for 17 x 7 or 7.5 wheel?
Thanks for any leads
Old Mar 22, 2004 | 06:20 PM
dandp's Avatar
dandp
I know the Pirelli P - Zero Corsa is considered a "competition" tire, 215/45/17
Old Mar 22, 2004 | 06:22 PM
dandp's Avatar
dandp
And Hoosiers, Kumho 205/40/17 as well. If you look under "competition" on tirerack, you'll find a few choices....
Old Mar 22, 2004 | 06:25 PM
MSFITOY's Avatar
MSFITOY
Would the 215/45-17 raise my gear ratio? I know the 205/40 lowers it a bit and that's what I was considering.
Old Mar 23, 2004 | 09:32 AM
Alex@tirerack's Avatar
Alex@tirerack
215/45 is slightly taller, 205/40 is severly undersized, 215/40 is the shortest I'd even entertain for race rubber.
Alex
Old Mar 23, 2004 | 11:09 AM
MSFITOY's Avatar
MSFITOY
>>Alex
Thanks for the info, Alex.
Questions...how much slightly taller is the 215 and which tires do you recommend for race application dry weather only?
Sid
_________________
Old Mar 24, 2004 | 09:00 AM
Alex@tirerack
>>Questions...how much slightly taller is the 215 and which tires do you .recommend for race application dry weather only?
Auto X or lapping?
Alex
Old Mar 25, 2004 | 04:02 AM
MSFITOY's Avatar
MSFITOY
>>Auto X or lapping?
>>Alex
Both preferably. Mostly limited dry weather street, then autoX, then track...in that order.
Old Mar 25, 2004 | 09:06 AM
Alex@tirerack
would you coincider fender lip surgery to accomodate a 225? I am concerned about race rubber in street conditions.
Old Mar 25, 2004 | 10:48 AM
MSFITOY's Avatar
MSFITOY
I might consider surgery.
My Mini only sees dry weather...not even a puddle will touch it The only time it gets wet when I wash it
Old Mar 25, 2004 | 12:20 PM
Alex@tirerack
i have had great results with KD, this is 25.0 inches in diameter, so its a bit taller in diameter. Width was the complication requireing modifcation.
Alex
Old Apr 6, 2004 | 07:02 PM
TiMINITim's Avatar
TiMINITim
What does "surgery" entale???
>>Alex
Old Apr 7, 2004 | 07:57 AM
Alex@tirerack
Severe trimming of the fenderlips and possible reshaping of fender plastic in board of the wheel.
Alex
W0TM8
Dec 19, 2019 07:50 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
TJANK
Aug 24, 2015 06:11 PM
