Brake issues R53
Old Aug 17, 2012 | 03:47 PM
smitty3896's Avatar
smitty3896
Brake issues R53
Lately i have been noticing that when I lightly press the brakes on my R53, such as just slowing down a little bit on the highway, the whole car has a pretty violent shutter. Then if i apply a good amount of pressure i can feel the brake pedal shaking under my foot but the wheel and rest of the car dont shake as much. Any ideas whats wrong?
Old Aug 17, 2012 | 03:49 PM
Scanner's Avatar
Scanner
may be warped rotors, ABS sensor malfunction, or caliper problem...any dash lights on ?
Old Aug 17, 2012 | 05:07 PM
smitty3896's Avatar
smitty3896
I was thinking that it was the rotors...but no no dash lights on..is there anyway to check the rotors without physically pulling them off and inspecting them?
Old Aug 17, 2012 | 05:28 PM
TimMc's Avatar
TimMc
You can put a dial indicator on it and read the gauge as you spin the rotor. If its bad enough you may actually see the rotor get closer and farther from the pads as you spin the rotor.
Old Aug 17, 2012 | 05:43 PM
ACEkraut11's Avatar
ACEkraut11
Pull each of the front wheels and do a visual inspection. If you have any questions about what you see take a few pics and post them here for people to view. Your problem might be obvious once the wheels are off.
Old Aug 21, 2012 | 04:36 AM
smitty3896's Avatar
smitty3896
Took a look at it and the rotors are defiantly warped. Instead of going with oem or other plain surface rotors i'm looking into some nice new slotted/drilled rotors. I usually use outmotoring.com for all of my stuff but their rotors' are so damn expensive. I have found two other alternatives that are a lot cheaper. but i don't trust this first one because in the picture the bolt pattern is not correct and they keep mentioning it is for a "Mini Cooper Pepper"?
http://www.cquence.net/cquence-stree...2006-html.html
Also I found these which are from a company i have heard of and the website seems much better than the other one.
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Please give me any input you have
Old Aug 21, 2012 | 08:41 AM
BRGPA's Avatar
BRGPA
I stayed away from drilled rotors because of accounts about cracks starting from the drilled holes. Slotted are good- lots of decent suppliers. I went with ATE and they have worked well...
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Toolman
Jan 20, 2016 06:50 AM
