Fuel gauge on empty - tried everything to fix - ti signal implausible (no reading)
Old Aug 16, 2012 | 05:46 PM
eurodriver's Avatar
eurodriver
Hi NAM members,
My mother has a 2003 Mini Cooper S. The gas gauge on her car is always at empty with the red bar illuminated under her nav screen. Also the range is ---.
After searching this forum and reading about the issue, I changed both the fuel pumps with tested working used ones.
The gas gauge still doesn't work properly.
After further research, I also entered the hidden menu in the OBC and came up with the following:
In test #6.2, the display reads 3
For reference the values indicate:
Test 6.2 Shows value of Fuel gauge. 1= both senders OK, 2= sender failure, 3=ti signal implausible (no reading)
I have number 3 which means ti signal implausible (no reading) showing on the OBC.
Also after reading the mini specific obc codes in the OBC via test #14, the numbers I get are 11422 on test 1 and the other tests are 00000 (indicating one code)
Can anyone please assist me in troubleshooting this issue?
I tried to research the issue to the best of ability but I am still out of luck.
Thank you kindly in advance for any help.
Old Aug 17, 2012 | 08:00 AM
eurodriver's Avatar
eurodriver
Forgot to mention...
The gas gauge stopped working right after she got here navigation computer fixed. I don't know if that has anything to do with the fuel gauge.
Thank you
Old Aug 23, 2012 | 04:00 PM
Rated_R's Avatar
Rated_R
Thank you
Have you checked the connections behind the lcd. There are three plugs back there. Make sure they are all connected correctly. Who replaced/fixed the nav?
HaveATank
Sep 4, 2015 08:04 AM
David.R53
Sep 1, 2015 06:49 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
kwijmbo
Aug 5, 2015 09:00 PM
