Replaced Power Steering Pump - Not working
Old Aug 12, 2012 | 06:36 PM
Crusher16's Avatar
Crusher16
Hey everyone,
I just finished putting in a new power steering pump that my friend got from the Mini dealer over here.
Everything is connected, fluid is in, yet the pump still doesn't function.
It is an '03 MCS with a little over 100K miles on it.
I've tried disconnecting the battery again, then disconnecting the pump and letting everything sit for bit, then connecting everything back up. Still no dice.
Not sure where to go from here. Checked the fuses I could get to. DOA pump maybe? Or am I just missing something else?
Old Aug 12, 2012 | 07:04 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
check ALL the fuse under hood and under dash
Old Aug 12, 2012 | 07:06 PM
Crusher16's Avatar
Crusher16
I'm currently checking the 100a fuse under the fuse box under the hood, but the others so far look good.
Old Aug 12, 2012 | 07:36 PM
Crusher16's Avatar
Crusher16
Good fuses. Dead in the water on this one.
Old Aug 12, 2012 | 07:40 PM
ColinGreene's Avatar
ColinGreene
are both plugs connected?
is the main power in pushed all the way in?
Maybe its your car telling you you dont really need powersteering.
Old Aug 12, 2012 | 07:42 PM
Crusher16's Avatar
Crusher16
Both plugs are in. As far I can tell (and feel), the main power is plugged in all the way.
What else would cause no power steering other than a bad fuse?
Old Aug 12, 2012 | 10:00 PM
Crusher16's Avatar
Crusher16
no power to ps when the engine is running, should i check with the three prong harness on the pump?
Old Aug 13, 2012 | 01:00 PM
Crusher16's Avatar
Crusher16
The harness to the power steering pump has no power. From what I understand, it is supposed to always have 12v running to it?
Old Aug 13, 2012 | 01:59 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
If the 100 amp fuse is blown you will not get power down there. Good news is if you blew the 100 amp fuse, you still needed a pump.
Your are testing with a test light? You need to fully test both sides of each fuse.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Cereall
Sep 5, 2019 06:05 PM
azntaiji
Aug 13, 2015 03:24 PM
bc219
Aug 10, 2015 11:22 AM
nismo4life
Aug 5, 2015 08:31 AM
