Drivetrain Acessport + super knock and other codes
I have an acessport with several other mods, intake, boost tube, forge dv, and I'm running no muffler so just the resonator plus both cats. Well my car is throwing codes on my acessport. I've searched around and know that one of them is super knock but it's not clear what te rest are. What I want to know is a definite cause and solution to fix these codes because they shouldn't just be ignored right? The codes are:
P2d52
P2dcc
P2dcd
Please help!
P2d52
P2dcc
P2dcd
Please help!
As far as gas goes it's 93 octane only for me but almost everything has ethanol in it.
My injectors have always been loud, like ticking like an e30 but it's been that way since new.
Seafoam will clean some of the carbon out but the best way is to visually inspect the intake ports and clean manually if needed. Even that still doesn't address what crud you have in the combustion chamber. Adding Seafoam to the gas tank can help with that.
My car bogged down while driving on the fwy from work today. Checked and I also got codes P2DCD and P2D52.
I noticed the coolant reservoir was down to the minimum. After letting it cool down I opened it and it overflowed back up. Let it settled and now the reservoir is empty. Last time this happened, they replaced the thermostat which was back in May of this year.
Are both codes related to the thermostat? Could it be the fuel pump? This was also replaced back in May 2011.
BTW, the motor was replaced with a refurb Sept 2011 so I doubt carbon build up would be the cause?!?!
UncDeo
Nov 4, 2019 04:08 AM
embiggenedmini
Oct 15, 2015 12:36 PM
MasterShaftner
Sep 4, 2015 03:52 PM
