FS:: Enkei NP01 Set
Old Aug 5, 2012 | 04:29 PM
ToBFree's Avatar
ToBFree
Enkei NP01 Set
Category: Wheels & Tires
Price: $400
Location (Region): Midwestern
Set of four (4) used, lightweight, silver 17x7 Enkei NP01 wheels with Falken 512’s 205/45/17 tyers for a Gen1 MINI Cooper or S. Set has just under 6,000 miles on them and seldom used, however, the tyres are stamped as manufactured in 2005 and should be replaced due to age alone. Still do have some tread on them. Includes centering rings. Purchased from another MINI owner in late 2008 for $700, but I just never grew to like the silver. Set has a few light rock chips, asphalt marks on the inside, plus a one or two blemishes, all easily cleanable/repairable. These would look fabulous in black. Shipping to your location would be at your cost. Location is Ohio between Akron and Youngstown if desiring to pick up. Will consider meeting part way if within a 100 miles or so.
Private message if you’re interested.
Can see this set on my 2002 MCS in early 2009 at mu, towards the middle of the page.
Old Aug 7, 2012 | 04:55 PM
ToBFree's Avatar
ToBFree
mmmm. Not even one little bite? C'mon, they are really nice lightweight wheels.
Old Aug 7, 2012 | 05:19 PM
AutoxCoop's Avatar
AutoxCoop
What is weight per wheel
Old Aug 8, 2012 | 04:14 PM
ToBFree's Avatar
ToBFree
Actual weight is 34.2 lbs. with the indicated Falken tire mounted. According to them, that's about a 19 lb. tire. So let's say it's 18 today used, then the wheel is about 16 lbs. or so. A new Enkei Racing Series RSM9 in this size is shown as a 16.31 lbs. wheel. I can tell you these are definitely not S-Lites and you can feel they are lighter.
Old Aug 10, 2012 | 09:03 AM
ToBFree's Avatar
ToBFree
Old Aug 18, 2012 | 05:47 AM
ToBFree's Avatar
ToBFree
Price dropped to $400 today.
Old Aug 23, 2012 | 04:15 PM
C4RACER's Avatar
C4RACER
what is the offset?
Old Aug 23, 2012 | 04:27 PM
ToBFree's Avatar
ToBFree
I'll have to look/measure. I bought them secondhand a few years ago and don't have any paperwork. Being an older series there's no data to be found. Can't be much away from the 42-45mm range.
Old Aug 23, 2012 | 04:37 PM
C4RACER's Avatar
C4RACER
if you measure backspacing to the outside of the rim, that would be helpful.
Sometimes offset is stamped, but not always.
Old Aug 23, 2012 | 04:44 PM
ToBFree's Avatar
ToBFree
I took another photo and added it above. The inside has a code 17x7 J 40 which may be indicate the offset is 40. Perhaps the rest of the codes mean something you'll understand. I'd have to measure in inches and convert the dimension.
Old Aug 23, 2012 | 05:02 PM
ToBFree's Avatar
ToBFree
After some interwebs searching these are likely 40 offset. They are also likely an Enkei RP-01 not NP-01. I found some pics of RP-02's that look just like these.
Old Aug 23, 2012 | 09:12 PM
MiniMe91's Avatar
MiniMe91
Look closely at the picture shows 40mm offset on the back of the wheel
Old Aug 24, 2012 | 03:33 PM
C4RACER's Avatar
C4RACER
Ok - thanks. I can't use these. Need 42mm max to be legal for D-stock class SCCA.
Old Aug 29, 2012 | 03:21 PM
ToBFree's Avatar
ToBFree
Waszak
Oct 21, 2017 05:55 PM
actualsize37
Nov 18, 2015 08:58 AM
Richard Kellstrom
Sep 4, 2015 07:21 PM
tag1260
Sep 2, 2015 07:42 PM
