R56 Mini Jacking Point
Old Aug 4, 2012 | 05:55 PM
teamrodney's Avatar
teamrodney
Mini Jacking Point
Some time recently I came across a replacement part for the jacking point made I believe of machined aluminium but I can't find it anywhere. Does anyone by chance know who made or sells this piece?
Old Aug 4, 2012 | 06:14 PM
Danske's Avatar
Danske
http://www.outmotoring.com/mini-coop...ad_spacer.html
Found this
Old Aug 5, 2012 | 09:27 PM
mslatter's Avatar
mslatter
Interesting idea, as I was just jacking up my MINI today to rotate the tires. I usually don't use the jack spacer with my floor jack, though. I put the floor jack just to one side of the spacer (toward the center.) I put the "circle" of the jack right on the plastic about 10 inches away from the spacer. Then I jack it up, and put the jackstand under the spacer. I have generic Harbor Freight jack stands, and the spacer fits really nicely into the stand.
When I jack up the whole side of the car, I use a 2x4 of about 30 inches in length.
When it's just the fronts, I put the jack circle right on the plastic underbody. It's left a little mark, but nothing to worry about.
Old Aug 6, 2012 | 04:44 AM
teamrodney's Avatar
teamrodney
I feel like a dill as I had looked through Outmotoring for this item and missed it. Thanks.
Old Aug 6, 2012 | 01:00 PM
highlander709's Avatar
highlander709
I have two of these and they work great. I have also found that a hockey puck works almost as well, and they can generally be found for about $2 each + or - at an ice arena or sporting goods store.
Old Aug 6, 2012 | 05:21 PM
teamrodney's Avatar
teamrodney
ice hockey pucks might be a bit rare in Australia or a cheaper version of the Mini produce here :- http://burgertuning.com/BMW_jack_pad_adapter.html
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
