R50/53 Painted my calipers
Old Aug 3, 2012 | 10:38 AM
joschwab10's Avatar
joschwab10
Painted my calipers
Got a wild idea, though I'd paint my calipers red. Took my wheels off, did a quick cleaning job with some grease remover, masked off the rotor etc., lightly sanded the calipers with 320 grit paper, Sprayed 3-4 coats on each one.
http://farm9.staticflickr.com/8025/7...fa0cccfdea.jpg
http://farm9.staticflickr.com/8166/7...65096f2367.jpg
http://farm9.staticflickr.com/8430/7...a70dac3765.jpg
Old Aug 3, 2012 | 10:45 AM
csdaman2's Avatar
csdaman2
caliper paint
where did you buy the paint & how much?
Old Aug 3, 2012 | 10:53 AM
Fly'n Brick's Avatar
Fly'n Brick
You can get G2 from Tire Rack.
OP: Next time you have your wheels off, think about painting the disk hats too. It adds an extra 'pop' to the wheel well.
Old Aug 3, 2012 | 11:35 AM
joschwab10's Avatar
joschwab10
Got the paint from napa auto parts for 8 bucks. Works well and they have blue red and yellow
Old Aug 3, 2012 | 11:36 AM
joschwab10's Avatar
joschwab10
That looks awesome! Didn't even think about that
Old Aug 3, 2012 | 01:08 PM
ACallahan's Avatar
ACallahan
Kinda did the same thing but stepped up to R56 calipers.
https://www.northamericanmotoring.co...the-cheap.html
Old Aug 3, 2012 | 07:18 PM
joschwab10's Avatar
joschwab10
I had no idea that the R56 calipers fit on our R53's. good to know!
Old Aug 4, 2012 | 12:15 AM
dubstepsteve's Avatar
dubstepsteve
this is what i wanted to do. did any of you guys use high temp paint or a primer or clear coat? i wonder how long the paint will last on there
Old Aug 4, 2012 | 03:53 AM
CR&PW&JB's Avatar
CR&PW&JB
G2 will last for at least a few years. Maybe others can attest to a longer period.
Old Aug 4, 2012 | 07:48 AM
Fly'n Brick
Only reason I mentioned G2 is because it is better than what I used which was duplicolor or something from O'Reilly's. It looks ok when kept clean but is prone to rock chips and such which need touching up periodically. When I finally wear out these OEM brake pads I'm having the wheels, calipers and new disk hats professionally done.
Old Aug 4, 2012 | 08:19 AM
leaf_fan_1988's Avatar
leaf_fan_1988
I've been dying to paint my calipers for so long, it's been too hot and when the weather is right, I'm too busy.
Old Aug 5, 2012 | 01:03 PM
joschwab10's Avatar
joschwab10
Yeah the duplicolor looks good enough for me. I plan on upgrading to a BBK sometime in the future so the caliper paint works fine for now.
Old Aug 5, 2012 | 01:26 PM
ACallahan's Avatar
ACallahan
The G2 I think is a 2-part epoxy which is extremely strong and heat resistant, the other brands are high heat enamels which are not bad but just are not as tough as the G2, explains why the G2 cost more also.
Old Aug 5, 2012 | 10:01 PM
dubstepsteve
i never knew there was paint infused with epoxy?? thats pretty smart and im going to consider going this rout when i paint my calipers
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
