R50/53 Jerk when lifting off accelerator
Old Jul 30, 2012 | 01:29 PM
Xtrackdog's Avatar
Xtrackdog
I've done my searching, but would like to run this by you all.
The car is a 2005 MCS Manual Trans. 62K miles.
When I am at highway speeds, I feel a slight "single" jerk or lurch (not jerking) when I lift off the accelerator. The car is still in gear. I feel the same thing when I get back on the accelerator.
Almost all my searches point to the engine mount being the problem.
However, I do not necessarily feel any excessive vibration at idle nor when the A/C is on.
Has anyone experienced this, and had this solved with new engine mounts?
Thanks.
Old Aug 1, 2012 | 06:47 PM
Flipper & Punkin's Avatar
Flipper & Punkin
Look for oil stains on passenger side frame rail. If found, then hydraulic engine mount might need to be replaced. Ours was replaced circa 2010. Noise gone.
O
Old Aug 2, 2012 | 06:13 AM
Gizmo's Avatar
Gizmo
I am still trying to fix this in mine, I get it at various speeds. I have replaced my upper motor mount with an OEM mount and the lower motor mount with a BSH mount. The only one left that I have to change are the transmission mount bushings...hopefully that will fix it.
Old Aug 2, 2012 | 09:27 AM
astroBlackMetallic_Mini's Avatar
i believe thats called Torque my friend
ive had small jerks with all my manual trans cars... its just the nature of the animal
enjoy it!
Old Aug 2, 2012 | 09:28 AM
Gizmo's Avatar
Gizmo
Mine you can see significantly in the seat/accelerator pedal. I get more of a thud than a jerk.
Old Aug 4, 2012 | 02:32 AM
dubstepsteve's Avatar
dubstepsteve
id say dont drive so high up on the rpm and calm down on that led foot!
USNAE2
16
Jun 17, 2022 07:17 AM
M7Speed
Jul 10, 2018 09:26 AM
OutMotoring
Mar 3, 2017 06:29 AM
randeez
Oct 5, 2015 09:23 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
