R50/53 Rear hatch wont open!!!
Old Jul 25, 2012 | 05:54 PM
southerncoop's Avatar
southerncoop
Just removed my rear wiper blade to do the home delete kit and the rear hatch wont open now what do I do!?!
Old Jul 25, 2012 | 05:57 PM
jay80424's Avatar
jay80424
Take handle off and check connection? I had a similar problem. When it rained moisture would get into the hatch switch and it wouldn't open till it dried out. Dealer fixed it by replacing the assembly.
Old Jul 25, 2012 | 06:33 PM
southerncoop
next thing is that I can't find the emergency hatch release ring that is suppose to be in the back seat, as described in the owners manual. If it helps it is a 2002 manual Mini cooper base
Old Jul 25, 2012 | 06:36 PM
ZippyNH's Avatar
ZippyNH
On MOST gen1 cars, if you reach under the rear seat, there is a vable that will manually pull the latch open....
The button that opens the latch electrically might have gone bad....or some water got to it....you can take it apart..use some contact cleaner..or even replace the handle.
Old Jul 25, 2012 | 06:47 PM
southerncoop
Do you have to pull the bottom part of the seat out or up rather? I didn't see anything. And is it passenger or driver side.
Old Jul 25, 2012 | 07:06 PM
ZippyNH's Avatar
ZippyNH
just reach under, and feel for the cable...
some early cars did not have it...but the dealer retrofited them to most.
Old Jul 25, 2012 | 07:14 PM
chrunck's Avatar
chrunck
Grab the front of the seat and give it good tug upwards. It's just held down with a few clips, so you don't have to worry about breaking anything. There should be a yellow handle on a long wire. You can't miss it.
Old Jul 25, 2012 | 07:17 PM
chrunck's Avatar
chrunck
My bad, it's not yellow afterall. Here's a pic from my R53.
Old Jul 26, 2012 | 12:40 PM
ERIK06MCS's Avatar
ERIK06MCS
I remember reading somewhere that the early gen 1's did not have that release cable.. could this be why he can't locate it? I would hope this wouldn't be the case though!
Old Jul 26, 2012 | 01:17 PM
Capt_bj's Avatar
Capt_bj
That's right .... my 02-S which I bought in October off the delivery truck was a late Aug build as I recall and it did not have the release
or a jack
or brake wear sensors
all these things came later . . .
sorry 'bout that mate
Toolman
Jan 20, 2016 06:50 AM
coachvminis
Aug 17, 2015 01:42 PM
Aug 7, 2015 05:56 AM
