R50/53 Help Removing ATI Super Damper
Old Jul 21, 2012 | 10:07 AM
brettjameson's Avatar
brettjameson
I just installed an ATI Super Damper, the problem is now the serpentine doesn't have enough clearance because of the belt tensioned bolt on top. I need to back this damper up so I can slip the belt into the channel and then reinstall damper pulley.
Old Jul 21, 2012 | 10:25 AM
Eric_Rowland's Avatar
Eric_Rowland
Seems there should be another solution to this. You don't want to have to remove your crank pulley every time you change the belt, do you?
Old Jul 21, 2012 | 10:36 AM
clay44's Avatar
clay44
Put the belt in the channel on the ATI first and then slip it around another pulley. If i remember right i slid my belt over the idler pulley last when i ran into a similar issue.
Old Jul 21, 2012 | 11:09 AM
ACallahan's Avatar
ACallahan
If the ATI is on dont try to remove it to fix the problem that would be a big pain in the "S".
Old Jul 21, 2012 | 11:54 AM
BlwnAway's Avatar
BlwnAway
You should not have to, and do not want to remove or pull the damper off once its been seated.
There must be another problem, check your routing and to make sure the belt is properly alligned in all of the other pulleys, remember, belt should be slipped onto all the pulleys except the idler, compress the tensioner, then slip it on the idler.
Old Jul 21, 2012 | 12:24 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
+1 These folks are giving you straight advice. Compress tensioner, route belt, slip-slide belt on idler pulley last.
Old Jul 21, 2012 | 12:36 PM
Braminator's Avatar
Braminator
+2^
Old May 14, 2018 | 01:09 PM
Adam Pundsack's Avatar
Adam Pundsack
Help!
I am replacing timing chain guides due to chain rattle when engine is cold. I already tried 2 tentioners and nothing got better. How do I remove the ati super damper? : nevermind called ati there are bolts u take out then u can use a puller
Last edited by Adam Pundsack; May 14, 2018 at 01:42 PM. Reason: Found out by calling ati
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
cw40342
Oct 6, 2015 05:07 PM
greekzilla
Aug 23, 2015 03:44 PM
minipopkart
Aug 13, 2015 05:22 AM
