Electrical has anyone "decoded" the sunroof switch
Old Jul 11, 2012 | 10:04 AM
astroBlackMetallic_Mini's Avatar
i am in the process of developing a circuit / device that will open and close the sunroof (just tilt) when it is hot / wet respectively.
has anyone else done any specific mods to the sunroof? its switch?
is there constant power, can i supply my own power through the switch to tilt the sunroof? or is the whole thing controlled by the computer?
Old Jul 14, 2012 | 08:27 AM
chris.j.lamb's Avatar
chris.j.lamb
look here :- http://www.bmw-planet.com/diagrams/release/en/index.htm
Old Aug 16, 2012 | 06:13 AM
hey, that link works, but the data seems to be missing from the pages... any other help?
Old Aug 16, 2012 | 02:25 PM
jbkone's Avatar
jbkone
There might be a way to use the rain sensor (installed with auto wipers) to close the sunroof if it rained, but that might include keeping it active all the time thus draining the battery. Would be really cool though!
Old Aug 17, 2012 | 08:13 AM
i found a sensor online that a guy developed to close his roof on his convertible actually, so im going to adapt that. the circuit will be designed to only be energized when the sunroof is open. even so, he has already designed the circuit to use very minimal power.
plus with my rear sunroof solar panels, i always have a slight trickle charge on my battery anyway
but alas, i still need to decode the sunroof switch! nobody seems to have any info no it at all...
Old Aug 17, 2012 | 12:35 PM
chris.j.lamb
you MUSt install Java & Adobe SVG viewer to see the data.............
Old Aug 17, 2012 | 12:36 PM
chris.j.lamb
What is says about the system :-
Sunroof (SHD)
The sunroof is controlled by the sunroof module. The module contains all load circuits and is connected directly to the sunroof drive.
The module is allocated to the vehicle by means of encoding.
Components
Sunroof module
The sunroof module contains the following components:
DC motor with attached step-down gear mechanism (worm drive)
Two integrated position sensors (Hall sensors)
Electronic control
Switches
The sunroof is operated by means of a switch with five different switch positions.
Lift (switch pressed)
Slide OPEN (push back switch)
Close (push switch forward)
Slide OPEN - press and hold
Close - press and hold
The five positions are transferred via three lines to the sunroof (SHD) module (earth signal).
Automatic mode, which opens or closes the sunroof completely, is triggered by pressing and holding the switch in ”slide OPEN” and ”close” position.
If the switch is moved towards ”Lift” when the sunroof is open, the roof moves automatically to the end position ”Lift open”. The process can be interrupted by pressing the switch again.
Functions
Position detection and anti-trapping protection
Two position sensors (Hall sensors) register the number of motor revolutions and thus determine the position of the sunroof. The drive is switched off on reaching the relevant end position.
The torque of the drive is constantly calculated from the pulses sent by the position sensors and the power consumption of the motor. The torque increasing to above a certain value is interpreted as trapping. The characteristic data (characteristic curve) for the anti-trapping protection are defined in the coding data. They are written into the control unit during the encoding procedure.
The anti-trapping protection is active in the ”close” direction when the sunroof is open between > 4 mm and <200 mm. This function is active both during normal closing (switch not over-pressed) as well as during automatic operation and convenience closing of the sunroof. The anti-trapping protection is deactivated in the case of a fault by overpressing the switch in the close and hold direction.
The closing procedure is interrupted if trapping is detected and the sunroof is opened for approx. 1 second.
Important
The anti-trapping protection is no longer active when the sunroof is opened by less than 4 mm.
Initialization
Initialization of the sunroof involves recording the mechanical end positions (standardization) and learning the characteristic curve for the anti-trapping protection.
On sunroof modules with the diagnosis index 01 and 02, the characteristic curve for the anti-trapping protection is specified by the coding data. A separate procedure for learning the characteristic curve is not necessary.
On sunroof modules with the diagnosis index 03, the characteristic curve must be learned after standardization by means of a special process from the module.
Standardization
Since the position transmitters are integrated in the sunroof module, they do not have a fixed allocation to the sunroof mechanism. In order to achieve this allocation, the module must register the mechanical settings and store them internally. This procedure is termed standardization. Only the ”close” and ”lift” functions can be run with a sunroof that is not standardized.
The standardization is executed when the sunroof is moved into the mechanical stop of the position ”closed” or ”lift”. The stop is detected with an overshoot time of approx. 1 second.
New standardization is necessary after conducting repairs on the sunroof. Set the sunroof in the ”lift” end position for standardization purposes.
On reaching this position, press and hold the switch in ”lift” for at least 15 seconds. The old data is deleted and new standardization values stored. Brief activation of the sunroof drive indicates that the standardization is being run.
Note: if the sunroof stops before reaching the end position, keep the switch pressed and wait for at least 15 seconds (deletion of standardization values). The sunroof then continues to move. Keep the switch pressed for 1 second when the sunroof reaches the end position.
Anti-trapping protection characteristic curve
On sunroof modules with the diagnosis index 03, the characteristic curve for the anti-trapping protection must be learned after standardization.
The following procedure is necessary in order to learn the characteristic curve: after standardization, release the operating switch and, within 5 seconds, press it again to ”Lift” and keep it pressed. After approx. 5 seconds, the sunroof is fully opened and fully closed. During the process, the mechanical forces are recorded in the system.
The switch must be pressed during the entire procedure.
When the ”sunroof closed” position is reached, the learning of the characteristic curve is finished. The operating switch can now be released.
Important
So that the anti-trapping protection functions reliably, the standardization and learning of the characteristic curve must be run after all repair work on the sunroof!
Convenience operation
In the same way as the power windows, the sunroof can also be opened or closed together with locking or unlocking the vehicle.
Convenience opening takes place when the lock cylinder is held in the ”unlock” position for longer than 3 seconds or when the appropriate key on the remote control is pressed for the corresponding length of time.
Convenience closing takes place when the lock cylinder is held in the ”lock” position for longer than 2 seconds or when the appropriate key on the remote control is pressed for the corresponding length of time.
The functions can be activated or deactivated by encoding.
Old Aug 21, 2012 | 08:59 AM
jbkone's Avatar
jbkone
So according to this, the sunroof can be remotely closed? I'll have to find that encoding software!
Old Aug 21, 2012 | 10:12 AM
well, i can OPEN the sunroof via the key, but not close it. i can / do close everything using the locking of the car method.
that is all very interesting stuff! Thanks Chris! neat to know that this much time and effort went into JUST the sunroof!
i may still have to rip the switch apart however, if i cant find a wiring diagram :(
i need to know if i will have to supply POWER to the switch when the car is off, if i want to use external circuits to control the sunroof.
Old Sep 27, 2012 | 01:40 PM
mnkpnk's Avatar
mnkpnk
My mini doesn't have the sunroof convenience operation activated, I was researching on how to program it myself and actually found the wiring diagram,
http://wds.spaghetticoder.org/en/svg...6472.svg?m=r50
http://wds.spaghetticoder.org they pretty much have every diagram you might need
Hope it helps!
Filmy
15
Jun 6, 2023 06:27 AM
bahman
Sep 26, 2015 07:38 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
