Side Scuttle
Old Jul 9, 2012 | 01:37 PM
AgentCoop's Avatar
AgentCoop
Side Scuttle
Hi everyone,
I tried searching on this, but all I could find was the info for R56s..
This is 2006 MCS.
Here is the pic - my side turn signal marker (not sure if that's what it's called - it is the white lens inside the side scuttle that houses the bulb) fell off and is now hanging by the wires.
How do I replace it? I ordered the part from the dealer, but I'm not sure if I have to remove the entire "S" scuttle or I can just pop the white lens back in?
This thing is so fragile, I'm afraid to break it - not cheap these things :(
Thanks in advance.
Old Jul 9, 2012 | 01:43 PM
Braminator's Avatar
Braminator
The scuttle does not need to be removed. When you get the new one you will see 2 clips on it. Once you install the bubl, you will put on one side and press it in and you wil here it click. Thats it.
boostedhaze
Jan 2, 2018 07:26 PM
CM2011RG
Apr 12, 2016 12:44 PM
Ollie625
Nov 15, 2015 06:57 AM
cm.d
Aug 19, 2015 08:51 AM
CM2011RG
Aug 5, 2015 02:00 PM
