won;t start R1 fuse clicks
Old Jul 2, 2012 | 01:46 PM
sunny cal's Avatar
sunny cal
R52 2006 S conv.
Worked fine, one day, next day won't start.
Pulled batt. Pep Boys said it was dead.
Put in new battery, still won't start.
key in second position, r1 fuse i(pic. of engine with lightling bolt on box lid) in engine fuse box clicks. engine won't turn. Switched with R3 fuse (identical) sti9ll just clicks.
Any sweet ideas?
Old Aug 19, 2012 | 03:48 PM
gblackwood's Avatar
gblackwood
Did you get the issue resolved? Mine just developed the same issue.
Old Aug 27, 2013 | 03:49 PM
Kbron2000's Avatar
Kbron2000
did you find a solution???? minw it's doing the same thing
Old Aug 28, 2013 | 06:01 AM
RadioActiveMan's Avatar
RadioActiveMan
I had the same issue not that long ago. Check your ground cable in the engine bay. Mine was loose. I also sanded it down to make sure it was metal on metal.
I had replaced the battery and starter before checking the ground strap. Pissed me off something fierce.
You can see it strap in this picture.
Old Nov 9, 2016 | 09:08 PM
Ricky_Racer's Avatar
Ricky_Racer
Did any of you ever find a solution?
Old Nov 10, 2016 | 05:19 AM
MiniToBe's Avatar
MiniToBe
Ground strap on the engine side
Old Nov 10, 2016 | 04:00 PM
Ricky_Racer
I cleaned and tightened all grounds and even ran another ground wire to make sure and the R1 switch relay still clicks ):
Wohnson89
Jun 10, 2020 04:53 AM
Teh
Jun 13, 2018 02:59 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Aug 12, 2015 01:24 PM
nismo4life
Aug 5, 2015 08:31 AM
