R56 Alta Positive Steering Response System (PSRS)
Old Jun 30, 2012 | 07:38 PM
Melangell's Avatar
Melangell
Alta Positive Steering Response System (PSRS)... Worth it?
Old Jun 30, 2012 | 07:55 PM
Scooter09's Avatar
Scooter09
If you want to spend the day dropping out your entire front sub frame, removing the swing arms, getting the metal cylinders welded to said swing arms (more $$$) and then getting everything back together. The set screws supplied don't really hold well, even with some locktite, they tend to just grind away at the hex arm on the swing arm, making it loose. After trying to fix it a few times, I just took them out and put PowerFlex bushing in.
Old Jun 30, 2012 | 08:01 PM
Melangell's Avatar
Melangell
I was gonna say that I wouldn't do it, that Way would but.... Reading a bit more from other sources... I think you might be right.
AWOL
Mar 28, 2016 10:51 AM
theblackfalcon
Oct 11, 2015 09:49 AM
stierzy34
Sep 15, 2015 04:40 PM
iclancy82
Aug 11, 2015 09:35 AM
