Suspension What do you think advice and comments for 4 season DD
Old Jun 24, 2012 | 05:26 PM
Doc_Savage's Avatar
Doc_Savage
I have to do a full change on my suspension set up the Oem One is shut and instead of just changing the strut and shocks, I'd like to do a full set.
Since this his my DD and that I drive in winter with snow Ice and salt I choose to stay away from coilovers.
I Choose:
H&R touring cup kit item part # 31040t-1
HOTCHKIS H-SPORT 2-PIECE REAR CAMBER LINKS item part #13800
HOTCHKIS H-SPORT rear sway bars item part #22800r
WHITELINE R53 Rear end links item part #klc006
POWERFLEX Front wishbone rear bushing item part #pff5-101 (there's supposed to come by pair)
CRAVENSPEED strut tower defender item part #crmc-0040
I don't think I'm missing anything but you can correct me if I'm wrong!
Camber plates would be an overkill right??? or should a get some instead of the tower defender???
Old Jun 26, 2012 | 01:55 PM
00zero's Avatar
00zero
I have a similar setup to the one you are looking into but by no means an expert.
The rear end links are not necessary if you don't have coil-overs. They are used to remove pre-load on the anti-sway bar due to corner weighting.
If you are doing the strut tower defenders i would just go with the Ireland fixed camber plates. The added camber up font is a universally accepted good thing on minis.
The front control arm bruising do come as a pair.
-Jonathan
Old Jun 26, 2012 | 02:58 PM
Doc_Savage's Avatar
Doc_Savage
-Jonathan
Thanks jonathan for your reply
So your saying that I can ditch the rear end links, and instead of go with Craven speed ST defender I should go with camber plates I'd like some adjustment on the camber and to be able to adjust the damping on the struts (koni in the H&R kit)
What would you recommend
Thaks again
Old Jul 2, 2012 | 09:44 AM
00zero's Avatar
00zero
Correct, you don't need the end links just reuse the stockers. I only have the Ireland fixed camber plates, they add -1.25deg. while on most you will not have perfect camber match left to right unless you are racing i was told not to worry about it. Adj front camber is out of my realm of knowledge, i haven't used any of them. the Vorshlag seem to be the best but they aren't cheap but you can adjust your dampers. If you are unsure i would give any of the vendors a call they are are very helpful and will not lead you wrong. -Jonathan
Old Jul 2, 2012 | 09:48 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yeah unless your a race car driver the end links are not necessary. Plus that brand is noisey and will wear out.
Old Jul 2, 2012 | 11:06 AM
Doc_Savage's Avatar
Doc_Savage
Defenitly not a race car driver, Still trying to convince my wife to let me autocross the darn thing
Hey Way Just wrote to you on friday in pm don't know if you saw it
It was a very long and boring pm about me and my problems
Thanks a bunch anyway guys
freckles81
Jan 15, 2017 06:33 AM
rikaro
Nov 24, 2015 02:05 PM
zdw2082
Oct 5, 2015 09:59 AM
tristanwelch95
Sep 30, 2015 08:58 AM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
