R60 Need Help Programming Computer
Old Jun 3, 2012 | 03:13 PM
CalabasasCountryman's Avatar
CalabasasCountryman
Hello everyone. I just installed a new lower switch module in the center instrument stack that contains the button to enable the rear fog light; however, the light will only come on if the car' computer is programmed to do so. Does anyone know someone with the cable/laptop/program in the L.A. area that could help me out?
Barry
Old Jun 3, 2012 | 03:18 PM
Mojito's Avatar
Mojito
Your best bet is to look in this thread for someone with the tools and knowhow
https://www.northamericanmotoring.co...r60-guide.html
Old Jun 3, 2012 | 07:58 PM
inh's Avatar
inh
Where didja get the switch module!?!? I have the coding tools but no switch :(
Old Jun 3, 2012 | 09:58 PM
CalabasasCountryman
I ordered it from Sewell Mini in Texas for under $200.
Old Jun 4, 2012 | 05:37 AM
Koopah's Avatar
Koopah
Barry,
Mojito's link is great for following the progress of programming adventures on the R60. You might also want to read through the NCS Expert Directory link on the Gen 2 Electrical forum for folks who are listing their availability for NCS Programming.
HTH,
Old Jun 4, 2012 | 09:29 AM
printingray's Avatar
printingray
One of the menu in MINI Connected is Vehicle Info. It provides On-board info, Trip computer, and Vehicle status. On-board info lists travel range with current fuel level, average fuel consumption (MPG), and average speed. Trip computer lists departure time, trip duration, distance traveled, fuel consumption (MPG) and average speed for the trip. Vehicles status gives you visual notification of engine oil level, front and rear brake pads, front and rear tire pressure status, vehicle check (engine check?) and brake fluid level. Trip information can also be found in trip computer in tachometer information screen.
Old Jun 4, 2012 | 09:58 AM
CalabasasCountryman
Thanks "printingray". Not sure why you think that would be of help to a guy looking to program the car to activate a rear fog light....
Old Jun 4, 2012 | 10:56 AM
printingray
Whats about the multipurpose vehicle intelligent programming systems, wireless keyboards and touch pad back light, made in china and offering cheap rates.
Old Jun 4, 2012 | 10:59 AM
Mojito's Avatar
Mojito
The products and procedure he needs has been posted, he just needs someone with the products and know how to do it
Old Jun 4, 2012 | 11:04 AM
CalabasasCountryman
Exactly Mojito. I need someone in L.A. to program the car. I also want to change the opening settings on the moonroof and override the vehicle in motion video override as well.
Old Jun 4, 2012 | 11:36 PM
bmwr606's Avatar
bmwr606
where is the rear fog light on a countryman? i thought i read on here that there was none?
scott
Old Jun 5, 2012 | 06:02 PM
Koopah's Avatar
Koopah
Did you check the NCS Expert Directory referred to in my last post?
Old Jun 7, 2012 | 03:44 PM
hyde76's Avatar
hyde76
I can help you if
1 - you want to come down to North Orange County. That's where I am. and..
2 - You know which code needs changing to enable your rear fog light which none of us know where it is.
I have a cable and a working laptop. Coded my own car. I cannot help with the video in motion however. That's more than uber complicated and I won't even attempt it. Everything else though is pretty straightforward.
Old Jun 7, 2012 | 03:46 PM
Mojito's Avatar
Mojito
I was playing with the configurator for the roadster or coupe, and theres a $100 option for the rear fog light.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
madmix
Oct 5, 2015 09:58 AM
tcjake
Sep 30, 2015 08:14 AM
dutchhome
Sep 30, 2015 07:17 AM
