DUNLOP tires??
Old May 30, 2012 | 06:48 PM
NC Mini's Avatar
NC Mini
DUNLOP tires??
I can get a discount on Goodyear/Dunlops. Has anyone used the Dunlop Direzza DZ101 ? I am thinking about he 205/45/17 or the 215/45/17. Any input would help. Thanks
Old May 31, 2012 | 06:07 AM
JimR56JCW's Avatar
JimR56JCW
I have had the Dunlop star spec 215/45-17. Very good grip wet or dry.
Old May 31, 2012 | 09:34 AM
JPMM's Avatar
JPMM
Star Specs +1
Old May 31, 2012 | 01:32 PM
proximo's Avatar
proximo
I've used them, but the 245/45r20 size. They are a good dry tire -- comparable to the Pirelli PZero's, but that particular one's wet is not so hot. Comfort and noise levels are about comparable.
Old May 31, 2012 | 05:15 PM
Jim Michaels's Avatar
Jim Michaels
If I were forced to buy either Goodyear or Dunlop summer tires in one of those two sizes, I think I'd consider the Dunlop Star Spec in 215/45/17, and also the Goodyear Eagle F1 Asymmetric in the same size. The Dunlop is an Extreme Performance tire with gobs of dry grip, but they wear fairly quickly and provide a somewhat harsh ride. The Goodyear is a Maximum Performance tire, so gives up some dry grip in exchange for somewhat slower wear and a somewhat better ride. They are similarly priced at Tire Rack ($145 and $148). I'd probably prefer the 205/45/17 size for more tire clearance, but didn't see any Dunlops or Goodyears that I would consider in that size.
Another option is to forgo the discount and buy the tires you really want.
Old Jun 2, 2012 | 09:58 AM
howsoonisnow1985's Avatar
howsoonisnow1985
What ^^he said^^ I would go with the Dunlop Star Spec if your an ensthusiatic sport driver and the Goodyear Eagle F1 Asymmetric if your just a commuter. I never tried the Dunlops you are referring to but I did hear negative comment about them, that they felt greasy around turns.
Old Jul 26, 2012 | 02:15 PM
NC Mini's Avatar
NC Mini
Thank you for the input
Old Jul 26, 2012 | 11:20 PM
hsautocrosser's Avatar
hsautocrosser
Note that the Direzza DZ101 and the Direzza Sport Z1 Star Spec are very different tires.
Old Aug 7, 2012 | 12:08 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Both 205/45-17 and 215/45-17 will fit MINIs with stock suspension, 215/45-17 is taller than stock tire diameter so less clearance on lowered MINIs.
Dunlop Direzza Sport Z1 Star Spec (Extreme Summer tire)
215/45-17 $147 each, 200 treadwear
Tirerack test results-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=118
Very good handling and grip but a little noisy and wears faster
Dunlop Direzza DZ101 (Ultra High Perf Summer tire)
205/45-17 $129 each, 300 treadwear
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=97
OK tire not as good in the wet
Another choice-
Goodyear Eagle GT (Ultra High Perf All Season tire)
215/45-17 $117 each, 400 treadwear
http://www.tirerack.com/tires/tests/...y.jsp?ttid=113
Good value, good in dry or wet, longer treadlife trading off ride comfort.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
