Drivetrain o2 sensors replacement and check engine light staying on
Old May 23, 2012 | 05:00 PM
beatles7117's Avatar
beatles7117
I replaced both o2 sensors in my 2006 s and the check engine light stays on .
I can reset and it will stay off until the car has cooled . I check with my ob2
tool and it says the o2 sensor . What am I doing wrong?
Old May 23, 2012 | 06:33 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Did you use OEM sensors or did you source them from somewhere other than a dealer?
There are a lot of instances where the correct sensors do not work correctly unless they are OEM sourced. Why? I don't know and I have not seen an explanation. But I have seen the problem described more than once.
Rich
Old May 23, 2012 | 07:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sorry but the adaptation values have to be cleared using a factory MINI tool, just a OBD scanner can't do it.
Old May 30, 2012 | 05:14 PM
JumpingJackFlash's Avatar
JumpingJackFlash
If you bought aftermarket Bosch O2 sensors, they will plague you with engine code issues. You need the NTK OEM equivalent sensors. Read more here: https://www.northamericanmotoring.co...r-install.html.
Motown
Apr 20, 2018 09:31 AM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
