R58 Running lines/wires under the car - Aquamist prep
Old May 14, 2012 | 02:41 PM
TazMinianDevil's Avatar
TazMinianDevil
So I looked under the coupe last night in prep for my Aquamist install and noticed that it's flat and clean on the underside. The only frame tunnel is where the exhaust is. I'm used to seeing several tunnels to the side where lines and wires usually run.
Has anyone else been under a coupe/roadster and found where they are running the fuel lines and electrical to the back? Am I missing some secret cover/guard?
Old May 15, 2012 | 12:41 PM
2009R56JCW's Avatar
2009R56JCW
I mounted the pump under the windsheild cowling and used the windsheild washer tank for the water/meth tank.
quick,clean and easy install.
Getrieben
Sep 12, 2024 07:03 AM
Lt. Dan
Aug 10, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
fm.illuminatus
Aug 10, 2015 12:15 AM
