Suspension Anyone care to take some measurements of the stock springs?
Old May 13, 2012 | 05:06 PM
inh's Avatar
inh
Hey guys. I was hoping someone who has put on lowering springs might still have their stock springs laying around and could take some measurements for me please. I need inside and outside diameter of both ends as well as the overall length. I want to contact some companies and see about getting some adjustable coilover sleeves made.
Thanks guys (and gals!)
Old May 14, 2012 | 10:32 AM
threar's Avatar
threar
I'm away from home for this week, but if no one has replied by the weekend I can take some measurements.
Old May 21, 2012 | 11:19 AM
inh's Avatar
inh
No takers? Can ya help me out please threar? Thanks :-)
Old May 23, 2012 | 05:35 AM
isthar's Avatar
isthar
I can tell you this, assuming normal load (defined as each front seat in center position w/ 150lbs), center of rear seat with 150lb, cargo with 37.5lb and full fuel):
Ride height (measured from lower edge of front wheel arch to bottom center of lower wheel rim flange)
standard suspension here:
for the 17s: front: 23.15in ; rear 22.44in
let me know if you need more, this is from the bentley svc manual
Old May 25, 2012 | 12:54 AM
inh's Avatar
inh
Thanks isthar, but I need the actual dimensions of the stock springs so I can get in touch with Ground Control and see about an adjustable coilover sleeve setup
Old May 25, 2012 | 09:06 AM
y8s's Avatar
y8s
you can maybe get away with just measuring OD, wire diameter, and number of coils / number of active coils.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Mini7
Feb 2, 2016 07:52 PM
ltjpunk7
Sep 6, 2015 07:32 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
Emnotek
Aug 13, 2015 05:47 PM
