oil leak
Old May 6, 2012 | 04:15 AM
GregO's Avatar
GregO
oil leak
2006 S with 45,000 miles. Recently had power steering leak fixed. Now have a dime-sized oil leak that drips almost dead center below the engine when the car is parked level. I will likely replace the valve cover gasket and see if that fixes it. If not, is there a most likely candidate for that location (assuming it's not the drain plug) or is it the usual...could be various things given they'll all run down to that location to drip?
Thanks for any guidance!
Greg
Old May 6, 2012 | 07:33 AM
miniconcarne's Avatar
miniconcarne
Could be your crank sensor o-ring/gasket, pretty common for these to leak.
Old May 6, 2012 | 08:36 AM
ACallahan's Avatar
ACallahan
Also oil pan gaskets are known to "weep" mine has been doing it for a long time its just not serious enough or top priority on my list right now.
Old May 6, 2012 | 05:14 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Don't replace the valve cover gasket until you determine that it's the culprit. You'll need to remove the plastic lower pan and clean up whatever oil you find, then, over a few days' use, observe where it's coming from.
Old May 7, 2012 | 09:15 AM
quikmni's Avatar
quikmni
+1 on what TrackRat stated You need to try to determine where the leak is coming from before replacing parts. My guess would be the crankshaft position sensor.
When my car was under warranty I had a small oil leak. The dealer replaced the oil pan gasket. That did not solve the leak. I do not think the dealer even tried to determine where the leak was coming from, they just assumed oil pan gasket. I later figured out the leak was coming from the crank position sensor and I replaced the o-ring to eliminate the leak.
Old May 8, 2012 | 05:38 AM
THE ITCH's Avatar
THE ITCH
As others have said replace the crank position "o" ring first. It's cheap, easy to do, and a very good chance this is the problem. Do a search and you will see some good write ups on doing this using a rachet strap so you do not have to put your car in service mode. Motoring alliance has a good write up under "Crank sensor seal replacement"
Steve
Old May 11, 2012 | 07:36 PM
GregO's Avatar
GregO
oil leak
Thanks all for the replies! I will let you know what I find out eventually as it seems to be a very slow leak.
Greg
Old May 13, 2012 | 09:41 AM
PenelopeG3's Avatar
PenelopeG3
I had my oil pan gasket changed 4 time by the dealer before they finally wised up and checked the o-ring people are referring to....
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
