Suspension Magnetic Dampers
Old Apr 29, 2012 | 07:16 PM
DavidT's Avatar
DavidT
Magnetic Dampers
Tried a couple searches on this and no hits in this forum. Anyone running the new magnetic dampers on the Mini or are they even made for our cars?
Dave
Old Apr 30, 2012 | 07:28 PM
roadsterdoc's Avatar
roadsterdoc
None available. Closest option is Koni FSD. Not magnetic, but they self adjust via internal hydraulic channels and valves. They work great, have less parts to fail, cost less and weigh less than a magnetic setup.
Old May 1, 2012 | 03:06 PM
DavidT's Avatar
DavidT
Thanks Doc. Too bad, hear nothing but good reviews.
Old Jun 2, 2012 | 08:27 PM
Jahan's Avatar
Jahan
Magnetorheological dampers are not available in the aftermarket. The system relies heavily on input from many sensors on the vehicle and requires specialized proprietary software and highly skilled engineers to tune.
There is really nothing close to it available, it's basically a computer controlled semi-active system.
Koni FSD's are decent, but they are basically a normal passive shock with an additional spring loaded valve that allows them to be soft for high frequency bumps but stiff at low frequencies for good handling.
pglgp1292
Oct 5, 2015 06:47 PM
nashvillemini
Sep 30, 2015 10:26 PM
Emnotek
Sep 29, 2015 07:37 AM
krohm
Sep 28, 2015 12:16 PM
Vaderm34
Sep 27, 2015 09:25 PM
