R56 Lights always on?
Old Apr 23, 2012 | 06:54 PM
TheEggO's Avatar
TheEggO
Lights always on?
Hi. I'm new to the Minis and recently bought a 2010 JCW (so please forgive my ignorance).
Every time I turn on the car, the light turn on too (headlights, license plate, brake lights, etc.) The light switch only turns the dashboard gauges on. Is this normal? I feel kind of weird using my lights all the time.
I've never had a car with daylights before, so I really don't know if this is normal or not. I would prefer to change this to manual. Is it possible? If so, please explain how to.
Thanks!
Old Apr 23, 2012 | 07:37 PM
Btwyx's Avatar
Btwyx
Sounds like your daytime running lights are set to on. Have you read the manual, it tells you how to change setting like that. Its accessed through the set menu with the stalk button.
Old Apr 23, 2012 | 08:26 PM
gawannamini's Avatar
gawannamini
Yes, when you select daytime running lights the perimeter lights are on too. Still, I'd rather improve chances of being seen so I run mine.
Old Apr 24, 2012 | 08:01 AM
TheEggO's Avatar
TheEggO
Thanks for the info!
Old Apr 24, 2012 | 08:51 AM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
Old Apr 24, 2012 | 08:56 AM
ITMVSME's Avatar
ITMVSME
Maybe somebody can answer my question here. I have tried both ways daylight running lights on and off. But as long as my switch is set to auto my exterior and interior lights are on. I do know that the windshield was replaced.
Old Apr 24, 2012 | 08:59 AM
MCS Fever's Avatar
MCS Fever
We switched on the headlight switch at the dealership and have not touched it since. They always come on, and always turn themselves off. Makes for safer driving. We also always run the front fogs, and have the rear fogs option. The bright red rear fogs are great to switch on for the occasional tailgater.
Old Apr 24, 2012 | 09:01 AM
amancuso's Avatar
amancuso
You may not have auto headlights. They may just be in the on position. When left in on position, they turn on and off with ignition.
Old Apr 24, 2012 | 09:11 AM
ITMVSME's Avatar
ITMVSME
I have 2 different positions on my switch. On is turned all the way clockwise. and auto is all the way counterclockwise. Well Actually I guess more positions including off and parking lights only.
Old Apr 24, 2012 | 09:33 AM
Porthos's Avatar
Porthos
That or check to make sure that you don't have the lights turned on. Becuase you can leave them on also.
If it is DTRL you can go into the OBC and turn it off.
Old May 16, 2013 | 04:06 AM
Fahrvergnugen's Avatar
Fahrvergnugen
But shouldn't the DRLs just run only the headlights....
at a lower output, and not the tail lamps or side markers? That's the way it was on my R53. I like to leave the switch in auto position (otherwise why have auto lamps) but when I do, all of the damn lights are on just as if the switch was in on position, regardless of the ambient lighting. The xenons are burning at 100%. I don't want all of the lights on in the light of day, just a lower intensity headlight, i.e. a "daytime running light". I don't see any way to get that to happen.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
