R50/53 Window problem question and yes I've searched!
Old Apr 10, 2012 | 07:58 PM
thevin70's Avatar
thevin70
Just picked up a 04 R53, bought it knowing the passenger window didn't work.
Past owner replaced motor and told me it must be something else.
All I hear is a "Click" traced it down to the relay in the BC1 Module.
The motor is good and does roll window up and down depending on the polarity I use from a 12 volt source. So know banging on the door for me, I did do it before I opened the door panel though.
Here's what I have done: door panel off checked for power at motor nothing.
Tapped on both relay's on the BC1 circuit board hoping one might be stuck.
I have disconnected the battery in hopes of resetting.
1: Do I need to get the window in the down position and then put power to
it to possibly reset it?
2: Or does it sound like I need a new BC1 Module and if so I've read conflicting statement's whether a "Used" one will work, If I find the exact replaced numbers and all (which I have), is it a plug and play or will or can I get it reprogrammed seeing it's used, or do I just need to get NEW?
I'm a recent member but have lurked for 1 year or so until I final got a mini and then signed up. I hate asking question's and sorry for the long draw out question..
Vin
Old Apr 10, 2012 | 09:01 PM
clos8's Avatar
clos8
I have heard that tapping on the door where the motor is makes it work. I had something like this happen to me yesterday actually, My window all of a sudden didnt roll down. I tried to tap on the door and no luck, I then got off and opened the door and slammed the door shut and worked. window working perfectly now.
Old Apr 10, 2012 | 10:20 PM
SPDinNY's Avatar
SPDinNY
can you swap relays and see if the problem follows the relay? (drivers side with passenger side)
Old Apr 11, 2012 | 03:55 AM
thevin70's Avatar
thevin70
Are they swappable? looked like they are hard soldered into the board. But i didn't look they closely...I will look when I get home..
Old Apr 15, 2012 | 07:44 PM
thevin70's Avatar
thevin70
The relays are soldered into the circuit board, does look like somebody has been in there and marked the bad relay.
I might try to get the relay and solder one in.
If I don't do this and find a "Exact" replacement module numbers and all does anybody know if it will be a plug and play? or is it dealer reprogram time?
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
arf88
May 31, 2016 03:07 PM
Dec 23, 2015 10:36 AM
massmini03
Aug 12, 2015 11:19 AM
