R60 Fuse Icon Decoding
Old Apr 8, 2012 | 10:40 AM
Rktcyntst's Avatar
Rktcyntst
Fuse Icon Decoding
Currently on a road trip and the 12v power sockets went dead. In trying to identify which fuse may be the culprit, I encountered the attached and am having trouble figuring out which icon is the right one. I think it's F44, but if anyone here knows, my phone and iPad would be grateful!
Sorry for the sideways pic. I'm surprised I was able to post this from my phone!
Old Apr 8, 2012 | 06:28 PM
Rktcyntst's Avatar
Rktcyntst
It's F44 for future reference.
Old Apr 9, 2012 | 08:47 AM
hyde76's Avatar
hyde76
Is there any way to configure this fuse, #44 to always be on, even when the car is not on? I was able to do this in my wife's Jeep. This way I could charge my phone in the car while it's not on.
Old Apr 9, 2012 | 09:41 AM
Flamewinger's Avatar
Flamewinger
I'm thinking that these 3 icons represent the power outlets. There are 3 of them and ther don't seem to be 3 of anything else. Can't find #44 though.
Old Apr 9, 2012 | 10:37 AM
rkw's Avatar
rkw
Uhhh... in post #2 the OP was confirming that the power outlet is fuse #44. I haven't seen a wiring diagram for the Countryman, but the other MINI models have two outlets that share the same fuse. It wouldn't be surprising if all three outlets in the Countryman are on the same fuse.
The icon is appropriate for a power outlet. I thought it interesting that they no longer use a cigarette icon, but in many markets MINI comes standard with only filler plugs, no actual lighter plug (optional).
Old Jun 20, 2012 | 07:23 PM
jimmyasch's Avatar
jimmyasch
2010 Cigarette lighter fuse-come out, come out wherever you are...
Hi all,
Just bought a 2010 base model, and the cigarette fuse(s) do not work at all. I was hunting for the fuse-and unable to locate.
Any help would be greatly appreciated.
Old Jun 21, 2012 | 03:46 AM
Sealy's Avatar
Sealy
I ran that picture through the Google Translator and it came back with - -
"In the fourth year of his reign, the almighty Amon Rah brought forth on the great Nile River . . ."
Old Jul 2, 2016 | 04:46 PM
mikeythemars's Avatar
mikeythemars
Since we are on a fuse icon tangent, does anyone have an idea of what symbol represents the radio/cd head unit? On a BMW board, I found one discussion where a poster put a detailed chart showing the BMW fuse symbols and their definitions. Many of the symbols were identical to the ones on the Mini chart.
The symbol that post said represented radio/AV circuits was the rectangle with a line in the middle and a dot at each end of the line (just that, not the version with what appears to be a black monitor screen above the rectangle). On my R57, the fuse diagram shows three separate fuse circuits with that symbol. That makes me wonder if those represent one circuit for the head unit, another for the external amplifier and a third for something else "entertainment system" related?
Or is that rectangle symbol representing something else entirely?
Old Jul 2, 2016 | 07:16 PM
pkunk's Avatar
pkunk
I was given these
Old Jul 2, 2016 | 09:32 PM
mikeythemars
Originally Posted by pkunk
I was given these
pkunk, thanks so much!
F5 is the one of the two circuits in my R57 that has that rectangle symbol, is a 20A fuse and is listed in what you shared as "sound system amplifier." However, when I opened up the cabin fuse compartment in my MINI, the slot for F5 was empty; I've never removed any fuses, so that is the way my R57 was delivered.
That suggests MINI/BMW was putting a 'generic" fuse location sticker on the cabin fuse compartments doors of 2nd gen MINIs (similar to the one at the beginning of this thread) but simultaneously omitting (or possibly adding) fuses depending upon the specific configuration of a given MINI coming out of the factory.
The other fuse listed on my sticker with that rectangular symbol is R49, which your photos didn't include. I'll go ahead and test it with a piggyback fuse adapter to see when it conducts voltage. What I'm looking to do is locate a fuse circuit that is only on when the audio head unit and/or external amp is running; need that to send a 12+v turn on signal to a separate subwoofer amp I just installed.
I've seen other info that supposedly indicate what wires in the HK harness carry external amp turn on voltage. Integral Audio says it's the black wire coming out of pin #1 on the X15 connector, but in my car, that wire is +12V constant (even when the car is idle with the fob out of the holder). Another post here said it's a white wire in pin #10 in the grey part of the connector going into the HK external amp (yes, a white wire somewhere in that tangle of wires in the right side of the photo below; I haven't found or tested that one yet).
HK amp with connections
UPDATE: I tested fuse R49 this morning. Still not sure what it powers, but did determine it immediately turns on when the key fob is inserted. So to quote U2, no, I still haven't found what I'm looking for (the fuse circuit that powers the head unit and/or the remote amp turn on line coming from it).
Next step is to remove the driver seat again, take the cover off the HK amp, unlatch the wiring the harness going into to it and see if there is a white wire (which one credible source says is the amp remote turn on) in pin #10 of the grey connector half. If there is, test it to see if it indeed goes 12+V when the head unit is turned on.
Old Jul 3, 2016 | 08:08 AM
mikeythemars
You'd have to do what you likely did in your wife's car: re-wire it to a constant on circuit.
Old Sep 1, 2016 | 11:10 AM
the cahuna's Avatar
the cahuna
I recently had the same issue of a blown fuse for the cigarette lighter now called a power outlet in my R60 countryman. It is the R44 20 amp fuse. the symbol you will see on all models I suspect is the - and + symbols on each side of a partial circle with a dot and then arrow to the right. Of course that is a power outlet because they have positive and negative terminals! how silly of me or how silly of mini for not putting it in the manual.
Old Jun 17, 2017 | 06:29 PM
Wealey1422's Avatar
Wealey1422
I've been seriously upset working on my R56 and saw this and busted up laughing. Thanks for the humor!
Old Dec 8, 2018 | 08:54 AM
Ben Blakemore's Avatar
Ben Blakemore
Remote locking
Hey guys, while your on the subject of fuses does anyone know which fuse is for the remote recieved in the rear view mirror
Old May 16, 2021 | 04:17 PM
sp_clark's Avatar
sp_clark
Good stuff here. Found a link via Google when looking for wiring color code translations. I'm wiring up a Tekonsha trailer light module, need to run 12VDC (fused for 15A) straight from battery to the module's power input according to Tekonsha.
Had been hoping I could use that boot-located charging socket but as it's not hot 24/7/365 the module would require programming every time my '13 R55 was turned on again. Kinda inconvenient but no worse I guess than running a #10 wire up to the battery compartment from the boot where the module's gonna be living.
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Nov 16, 2015 07:04 AM
mni928
Nov 9, 2015 07:38 PM
semibreve42
Oct 2, 2015 09:06 AM
krohm
Sep 28, 2015 12:16 PM
