Drivetrain lower motor mount alignment problems
Old Apr 1, 2012 | 04:31 PM
mdutton11's Avatar
mdutton11
Just put in a 15% alta pulley - pain in the ars. Having a problem getting the lower motoer mount to align back up - any suggestions? All other mounts are aligned with bots loose.
Old Apr 2, 2012 | 05:23 AM
BillyCuth's Avatar
BillyCuth
Did you remove both bolts or just the one that sits horizontally?
I actually replaced my lower motor mount while the engine was jacked up. When I brought it back down it lined up pretty much on its own. But, what you could do is remove the bracket that attaches the mount to the oil pan. It's held in by 4 bolts...
Old Apr 2, 2012 | 01:26 PM
HRM's Avatar
HRM
Just push the engine back with your hand. It only has to go about 1/8th of an inch. The up down can wiggle with the bushing.
Old Apr 2, 2012 | 01:43 PM
mdutton11's Avatar
mdutton11
Thaks for the suggestions. It took a lottle more force than just pushing with my hand but I managed to wrestle it back in. All is good and WOW - 15% Alta pulley made a HUGE difference in pickup (I like the whine too)!
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
