Anyone running 195/60/15?
Old Mar 13, 2012 | 07:40 AM
Mark140's Avatar
Mark140
I just put General Altimax HP's 195/60/15 on the Mini stock 15" wheels. They feel a little squishy but, only drove four miles. If you are running 195/60/15 what PSI are you running? I'd like to try adjusting the PSI first.
Old Mar 13, 2012 | 07:55 AM
Spooled's Avatar
Spooled
PSI is dependent on the tire brand/model, etc. It's not a one size fits all thing. Having the wrong pressure can give you uneven tire wear. Most any tire with an aspect ratio of 60 is going to feel "squishy". There's a lot of sidewall there to flex. You can try upping the pressure. It will help a little bit, but unless you're cornering like mad, you'll most likely get more wear across the middle of the tire than the outsides.
Old Mar 13, 2012 | 08:08 AM
DAVESTER's Avatar
DAVESTER
First of all, the General Altimax HP's is a "H" speed rated tire and that will be have soft sidewalls. The car came with "V" performance tires for the go cart feel. Secondly, you should have 205/60VR15 size to compare height to OE. Your speedometer will be closer to true.
Old Mar 13, 2012 | 08:22 AM
Mark140's Avatar
Mark140
The car came with these an "H" rated tire. I was not all that impressed w/ the tread wear on the Continental's <20,000. That and the speedometer is off by -5mph at speed anyway. With all that, I chose the Generals. I'll mess with the PSI a bit and see how it goes. I will say that the Generals are real quiet. Which is a plus in a commuter car.
Old Mar 13, 2012 | 10:04 AM
cristo's Avatar
cristo
Alliance Member
My winter tires are 195/60/15 Michelin Pilot Alpin PA2 on oem holies.
They're squishy, but mainly because they're winter tires.
Kimolaoha
Dec 5, 2020 09:32 PM
xpunisherx
Nov 27, 2015 03:32 PM
Nine Plan Failed
Oct 14, 2015 11:50 PM
Tektura
Tires, Wheels, & Brakes
18
Sep 13, 2015 10:00 AM
